Question about Garden
Craftsman weedeater will not start
Turned adjustment all the way still will not start. Changed spark plug an d changed filter
    Genius:
  • 1,554 Answers
Remove the spark plug , an go in dark area, pull start , do you see sparks , or just grab the plug an pull it, does it hurt.(ground one side of hand to the metal so it don't course thorough ur body.
so you have spark or not ,
no ,then theres the answer magneto is shot.
yes, then take off the filter an give it some gass or just spray a bit in cyl as you put the plug back from testing the spark.
does it cough or run when gas is added into some port
no then the cyl is cracked or needs oiled , spray some oil an gas in the head w/spark removed, let it set .
Posted on May 07, 2014
Robin Subaru (14 hp) engine will only run at idle. Increasing the throttle causes it to stall.
I had a similar problem on a weedeater one time, have you checked the exaust for a blockage?
Oct 12, 2014 | Motorcycles
I have a craftsman 21032 weedeater and it will not start. I have changed the plug checked for ignition cleaned the carb and checked if the valves are stuck. I have no clue what to do next
First check and make sure the gas lines are not cracked or rotted. This is very common. I assume you are getting spark if you checked the ignition. If the spark is good then it is a fuel issue or something internal
Aug 02, 2014 | Garden
When i give my stihl weedeater (fs 55) gas it dies. i changed the gaskets in the carburetor, new spark plug, new air filter. it idles fine just when i give it throttle it dies
This could be from a bad fuel filter (has a dark appearance when dry), from the spark arrestor screen in the muffler being plugged up with carbon deposits (take out the spark arrestor screen and clean it by burning off the carbon deposits), or the carburetor needs to be adjusted. If the carburetor needs to be adjusted I would take it to the nearest Stihl dealer that has a Gold Certified Technician. That way the unit is adjusted properly and is in good running condition. You can find a local dealer with the dealer locator. The link is HERE.
Mar 19, 2011 | Garden
Craftsman hand held gas leaf blower will not start. I have put in fresh gas, changed spark plugs, cleaned the gas filter, tested for spart and it does spark, changed the air filter but all this and still...
If it has a spark then try spraying some starter fluid on the air filter. If it attempts to run then the carburator is stopped up. If it doesn't then you most likely have low compression. Remove the spark plug and screw in a compression tester and pull the starter a few times. It has to have no less than 70 psi to fire and run. 90+ would be even better. If it is 50 and below try pouring a little oil in the spark plug hole and repeat the test. If it improves a little then you have a scored cylinder or piston or stuck or broken piston rings. Let me know what you learn and I'd be glad to walk you through some more.
Nov 04, 2010 | Craftsman Garden
Engine runs rough. I have changed spark plugs,
Check Flywheel Key, Carb Adjustment or if older engine also valve job.
Jul 17, 2009 | Craftsman Garden
Craftsman weedeater wont start
The problem that I had with my craftsman was that I found that there was a tube in the fuel tank that goes to the carb, & at the other end - inside the tank, there was a small screen with maybe a weight on it (to keep it in the gas no matter what position the weedeater is in). Mine was plugged up and i went to the saw shop and got a generic hose & end with the screen deal & changed them out. Solved my problem. Rick
Mar 24, 2009 | Poulan Genuine Weedeater Part # 36006-128
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
