What is wrong with my Roberts CR9955 clock/radio?
It was working fine until i unplugged it briefly and now it just comes on tries to set the time/date but then goes off, process then keeps repeating. Any help will be greatly appreicated?
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 142 Answers
Do you happen to see the "Low Bat" indicator on?
It may be worth trying to leave the unit powered off for a long time (= several minutes) and then retry.
You may try this over after removing and re-installing the battery (behind the cover with a screw on the bottom of the unit).
The battery is a frequently used CR2032 lithium cell, which you can find in many stores.
Posted on May 07, 2014
SOURCE: clock radio, small
Thanks, A great help
Posted on Sep 01, 2007
SOURCE: Emerson Smartset Radio Model CKS2288
The Daylight Saving dates appear to be hard-coded per the manual:
Start of Daylight Saving Time:
At 1:59.59 AM on the first Sunday in April, the clock will automatically advance to 3:00 AM.
End of Daylight Saving Time:
At 2:59.59 AM on the last Sunday in October, the clock will automatically reset to 2:00 AM.
So the easiest thing to do is to change your time zone up or down one for the period between the new DST date and the old -- or you can buy a new SmartSet for about $15. The newer ones do not have the same problem.
Posted on Mar 09, 2008
SOURCE: Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Posted on Jun 16, 2008
alfabette
  • 4 Answers
SOURCE: rp5430 clock radio aut time set not working
Slide the switch with a lock, wake 1, wake 2 and clock to the clock position. Using the backwards and forwards buttons get time to the correct time. When correct time is reached, slide the switch to the lock position. Time will now be set.
Manual can be found in PDF form from RCA here: http://support.rcaaudiovideo.com/Downloads.ashx?prodid=56&mediaid=620&force=true&file=products/RP5430/media/RP5430_UMEN.pdf
Posted on Jul 14, 2008
informatica
  • 1114 Answers
SOURCE: 12:33 keeps flashing
Hi - You can download the manual from the link underlined in blue below:
moz-screenshot.jpgRCA RP5420
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 31, 2008
After having a power cut yesterday our roberts cr9955 clock radio is now not resetting but on the display it says c:7L any ideas as to what is wrong with it.
Hello, Lucy -
I recommend you contact Roberts Radio Technical Service directly and ask about what the error display means and how to correct the problem. See:
https://www.robertsradiotechnical.co.uk/ContactRobertsRadioTechnical.aspx
I did find the manual for your clock radio online and found no mention of the error code you stated.
Best wishes.
Mar 03, 2018 | The Audio Players & Recorders
Alarm doesn't go off when set. I've adjusted the time. Still nothing
Try removing the battery and unplugging it form the wall for a few hours. This will allow the microprocessor time to discharge and reset to it normal functions. After letting the Clock/Radio discharge, you can put the battery back in the Clock/Radio and see if it has reset itself to the factory setting.Then use the link (http://www.emersonradio.com/owners) copy the web page link and paste it into the address bar of you browser. It will take you to Emerson home page for owners manuals. There you can find your model clock radio and follow the instructions for resetting the clock radios functions. I hope this information helps you with your problem.
May 20, 2009 | Emerson Smartset Clock Radio
Changed battery on roberts r871 radio .time date needs to be set
hold down mode button until display flashes, change time with up/down buttons. Press mode button once to change to date use up/down to move through dates, the time display will show year you are in the further you press the up button the further in the future you will scroll. This radio holds date & day information depending on the year displayed. Leave flashing to time out after adjusting.
Apr 27, 2009 | Emerson Audio Players & Recorders
Emerson Research Clock w/Projection Display Not Working
You will need to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio and remove the internal battery. Let the Clock/Radio set for at least 1 hour and then put the battery back in and plug in the Clock/Radio. The functions should return to normal. If not, replace the battery (CR2430) and leave the Clock/Radio unplug for a period of hours. Then put in the new battery and and plug in the Clock/Radio to see if the functions have returned to normal. If not you may have a more serious problem with the microprocessor. You can call the Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problem.
Mar 25, 2009 | Emerson Smartset Clock Radio
Snooze doesn't work anymore
1.You will need to reset the microprocessor of the Clock/Radio. To do this you must unplug the Clock/Radio and take out the internal battery. You must let the Clock/Radio set unplugged and with out the battery for at lease 1 hour. Then replace the battery and plug in the Clock/Radio and see if the functions return to normal.If not try replacing the internal battery (CR2430) and leaving the Clock/Radio unplugged for a few hours. Then put in the new battery and Plug in the Clock/Radio and see if the functions return to normal. If not you may have other problems with the microprocessor. You can call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance. 2.http://www.emersonradio.com/dst.htm Copy this web link and paste it into the address bar of your browser. This will take you to the Emerson customer support web page. This page has the procedure for setting the day light saving feature in your Clock/Radio. I hope this information helps you with your problems.
Mar 13, 2009 | Emerson Smartset Clock Radio
Day Light Savings Time
If you tip your clock over you will see three little buttons under. They are each labeled. Press/hold the one that says "clock" until your display blinks. Use the forward/back buttons on face of clock to re-set time, then press the little "clock" button underneath it again to keep the time you just set. It probably will beep.
When Congress's ideal day comes, re-set it the same way. Sorry, but all this will do is keep you from having to look at the wrong time for a few weeks straight.
Oct 28, 2008 | Zenith Z166S Clock Radio
Daylight Savings Times Changed
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
Oct 29, 2007 | Emerson Smartset Clock Radio
Operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
May 20, 2007 | Timex T311T Clock Radio
141 people viewed this question
 Grubhead
Grubhead
