Question about Kodak Easyshare M820 Digital Photo Frame Video Mp3 128m
Why does my digital picture frame rotate some pictures?
Recently my digital frame rotates some pictures so they appear sideways on the screen. I have them on a USB and checked that - they are all oriented correctly on the stick. They used to display properly, just recently have started to turn. Help!!
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 142 Answers
The picture orientation can be set manually.
You can download a manual here:
http://resources.kodak.com/support/pdf/en/manuals/urg00863/M820_M1020_frames_exUG_GLB_en.pdf
Check chapter "Changing your frame orientation".
Posted on May 07, 2014
mcomijohns
  • 477 Answers
SOURCE: my camera won't connect to my computer
This can be caused by several things. First plug up another USB device to that port. if it works you know your port is good. next hook up the camera and look in my computer for a extra drive letter. if you see on that is your camera. If nothing still see if you can hook it up to another persons computer to see if your cable and camera is ok. If the camera does work and none of these help out then it is a drivers issue. you will need to go into saft mode by hitting f8 when the pc first starts up goto option 3 safe mode now right click on my computer Icon and goto properties. Find device manager. in their click on hardware now find the USD devices and try to remove all of the usb listings once you have done that reboot the system the system will come up in normal mode. And start loading all of your usb devices again. Now hook up the camera and see if it works. If that does not work then in XP goto the system tools are in you accessories area. and choose system restore. choose the date closest to the last time it worked. Once you restore the system then hook up the camera again. This should work as long as all hardware is good.
Posted on Mar 24, 2008
jcdill
  • 121 Answers
SOURCE: Pictures Becomes white (Excess Exposer or ISO)
I'm not clear about your last sentence. It sounds like you may have accidentally set the camera to use exposure compensation to over-expose the images. To reset this, see page 27 in your user manual. If you don't have the user manual you can download it here from Kodak. If you said in your last sentence that this is not the case, I apologize for not understanding you clearly.
If this is not the case, then the light meter in the camera may be malfunctioning, telling the camera that it doesn't have enough light.
1) Make sure the light sensor is clean. This is the lower of the 2 small light buttons on the front of the camera, to the left of the lens as you face the camera. If that doesn't help try:
2) Use a - setting in Exposure Compensation to under expose the images to compensate for the damaged light meter.
If neither of these help, then it needs to be sent in for repair, or replaced. (If the camera is out of warranty it is likely that the repair cost will exceed the value of the camera and you should simply buy a new camera.)
jc
Posted on Dec 28, 2008
  • 86 Answers
SOURCE: when I take a picture with my easy share camera
Goto your setup or menu screen and select/deselect the auto orientation feature. If it is not there, then you are unable to change it.
Posted on Apr 16, 2009
leepania
  • 1099 Answers
SOURCE: was given a memory card for my Kodak M753 digital camera.
M753
Internal memory : 16MB
Memory card support : SD/MMC up to 2 Gigabyte
English manual:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00746/M753_M853_MD853_GSG_GLB_en.pdf
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 13, 2009
reitann
  • 214 Answers
SOURCE: Can't view pics on digital frame using new camera
You need to make sure that the pics are on standard jpeg compression, if not try opening file from your pc using mspaint then save file as jpeg
Posted on Jan 08, 2010
I can rotate pictures on my Aluratek digital photo frame but cannot get the rotation to save. How can I do this on the photo frame?
after u rotate the photo if you select the next photo in line , it should delay for a moment and say :updating: this it saving your rotation in its memory , or why not just rotate in in camera or computer , then save it to frame alllready rotated !!
Oct 20, 2016 | Photography
Once rotated photos on my computer to put on sd card the frame rotates them back
When loading pictures from PC to SD card you need to rotate and save at that stage!
Jan 02, 2016 | Photography
Pandigital picture frame manual
Unfortunately, there is no way to permanently fix the sideways photos while in the photo frame device. The only way to permanently fix them is to rotate them in your computer, and save them that way in the computer then re-upload the corrected pictures to the frame. Oh ya, you will have to delete the un-rotated pictures from the frame also.
Note: if the same name is used in both spots then the frame will take the newer one when it is overwritten on the upload to it therefore you will not have to go back and delete them manually!
Good Luck!
Rich Lilja
Jan 06, 2014 | Photography
Sylvania sdpf 1089
Rotate images correctly. : NIX Digital
https://support.nixplay.com/entries/66055804-Rotate-images-correctly-
Apr 7, 2015 - images that are uploaded to the frame should always display .... I amdisplaying images from my SD card. ... of photos coming from USB or SD will stillneed to be rotated if there is an exif ... "save as " from the account they are the correct orientation on my computer. .... Everything worked correctly after that.
Photo Rotation Problem - Community@Insignia
community.insigniaproducts.com/t5/...Photo.../Photo-Rotation.../td.../508...
Dec 28, 2009 - I have a few pictures that I already rotated correctly on my computer. Even so, they display incorrectly on the digital frame (buildings and people. ... When I bring the picture back to the picture frame, the rotation is still .... Just extra info - If I put the picture directly into Internal Memory .... Save as 24-bit Bitmap.
Galaxy S3: Photos are always being rotated! Why! - Android Forums ...
forums.androidcentral.com > ... > Samsung Galaxy S3
Dec 31, 2013 | Office Equipment & Supplies
How to save photo after rotated
If you use "Windows Picture and Fax Viewer" you can use the rotate buttons on the bottom of the program. And then simply hit either the left or right button and this will save it for you.
May 04, 2011 | PANDIGITAL 7-Inch Digital Photo Frame with...
I can't rotate pictures
They can be rotated in iphoto.
Mar 30, 2010 | Nikon Coolpix S210 Digital Camera
How do I keep a photo rotated?
Not all frames can save rotated images. Try rotating a photo on the frame's built-in memory, not one on a memory card. If it still does not save, then this model does not save rotated images.
Jan 01, 2010 | PANDIGITAL 8.0" Digital Photo Frame...
Pictures are cut off! Just got a 8 inch Pandigital photo frame for Christmas and loaded pictures on it. Since it does not have auto-rotation, I manually rotated any pictures that needed it before I put...
The frame is cropping the images to fill the screen. You need to change the image display settings from Optimal to Original in the setup menu. This way the entire image will show.
Dec 30, 2009 | PANDIGITAL 8.0" Digital Photo Frame...
Downloading pictures that are sideways...
All you need is some editing software, click here. If this problem is occuring after uploading to a website, try rotating the picture before uploading so the "problem" will actually correct the picture.
Jun 23, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Kodak Easyshare M820 Digital Photo Frame Video Mp3 128m Logo
107 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
