Question about Cub Cadet Garden
Cub cadet magnetic clutch engages slowly - Cub Cadet Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Bad clutch replcae with new one
Posted on Dec 17, 2014
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
panilling9
  • 284 Answers
SOURCE: cub cadet mower pto will not stay engaged while
be sure your battery is good and your system is chargingning the battery while run
Posted on May 26, 2009
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
  • 146 Answers
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 07, 2010
Cub cadet lt1046 pto will not engage . When I pull the switch it does nothing suggestions??
check under mower were it plugs into the clutch and be sure it is connected good. check fuse. test switch. test clutch. some times if you wiggle the wires going into the clutch it will engage if it does you may be able to take the clutch off and solder the wires where they are frayed.
Jun 08, 2017 | Cub Cadet Garden
LGTX 1050 Cub Cadet PTO will not engage blades on mower deck
If its an electric clutch it may not be getting power use a test wire from batter touch it to clutch and if you here it engage its ok sometimes the get corroded a bit and wont lick in but sounds like no power to clutch.
Apr 05, 2017 | Cub Cadet Garden
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
Hello, I have a Cub cadet tractor model 2164, and
BEARINGS ARE BAD IN CLUTCH REPLACE THE PTO
Oct 30, 2013 | Cub Cadet Garden
How does the PTO on a cub cader LT 1042 operate?
Sounds like the anti rotation bracket is not engaged in the side of the electro magnetic clutch, there will be a bracket or plate or bolt fixed to the chassis that engages into the outer edge of the clutch to stop the whole unit from spinning
May 15, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet zero turn clutch will not engage
If the clutch will not engage it can be that the cable is not regulated to pull the clutch enough
this is an idea on a real car.
thanks
Jul 12, 2011 | Cub Cadet Street Sign- tractor lawn riding...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Engine stalls when electric PTO clutch is engaged
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
26 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
