Question about Whirlpool LER4634J Electric Dryer
Whirlpool not blowing or tumbling
I think our whirlpool recently overheated and we have since cleaned everything out but now it won't tumble or blow air but the heating element does come on in the back, what can we check?
    Sergeant:
  • 212 Answers
Check to see if belt is still on drum. might have broke. thats the only thing that would cause the drum not to rotate but still should have air flow. the blower wheel is hooked up to the motor itself. your problem might be the motor itself has gone bad. if belt looks good then your motor is not turning.
Posted on Jun 22, 2009
Whirlpool Tumbledryer AWZ-121/3 OVERHEATING PROBLEMS
When was the last you cleaned the hose leading off he back.
Pull the dryer out and remove the exhaust hose (probably held on with a hose clamp so you will need a flathead screwdriver.
Once it's off take the hose from a vacuum or shop ac and stuff it in there and get out everything you can. Do the same win exhaust hose, and from the front at the lint filter.
Jun 14, 2016 | Whirlpool Dryers
How do i fix a tumble dryer blowing cold air
When you have to put this question here, I don't think it is wise to try to repair it yourself. It can be caused by lots of different things, Like a defective heater, a lose connection or a defect thermostat. When your dryer does not have an overheating security switch that came out and you can't reset it, a skilled technician should see into the dryer. It works with voltages, to dangerous to work with, when you don't know what you are doing. Please be careful.
Jan 30, 2015 | Indesit Ariston Creda Hotpoint Tumble...
Not spinning
A dryer has a lot of parts to make it heat, tumble and blow air. If it quit tumbling there are many things that could be wrong. You could start with checking the thermal fuse or belt switch or door switch, from there your into timers and motors. If you have electrical experience go for it :-) unplug first ;-)
Aug 02, 2014 | Whirlpool Dryers
My drier doesn't get hot but it still tumbles
The elementf2f2ac3.jpgor if that is ok look for lint blockage that can blow dryer thermal b3b8df4.jpgsafetys 87e64db.jpgIf that is good and you have 240 volts ac to the machine then the timer may have a bad contact c92b935.jpg5aee1f0.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 22, 2010 | Whirlpool LER4634J Electric Dryer
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool LER 6620 heats, but does not tumble.
if the dryer heats the motor should be good. if it hums its either runing or the hum is a stall noise . if belt is in tact then if motor were going so would the drum . so i think the motor isn't going just humming and the heat sw in the motor is stuck closed with lint and you need to replace the motor .. take the belt off and turn motor if it turns free . the blow it out good and reinstall belt and try again ..mm
Dec 03, 2009 | Dryers
Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 | Dryers
Whirlpool Dryer tumbles, but no heat, no timer.
try turning your breaker off then on and advise me
Dec 31, 2007 | Dryers
WHIRLPOOL AWZ2303 TUMBLE DRYER ONLY BLOWS COLD
It's call a bad thermal cut-out. You should have a thermal cut-out and a high limit thermostat located adjacent to the heating element (usually mounted right on the heating element housing). They both should read a short or fairly low resistance in the case of the thermostat. If the thermal cut-out is blown it is not a resettable device and must be replaced. The tco is usually sold along with the high limit thermostat. It is HIGHLY recommended that you replace BOTH at the same time. DO NOT attempt to bypass any of these devices either. They are there as safety devices to prevent overheating. You could end up with a fire if you do. Now...with all that said, the tco will blow for a reason. Not cleaning the lint trap will contribute to it, but the big item is the ducting. If the vent ducting is clogged you will experience longer dry times and eventually the tco will trip again. Take the time to THOROUGHLY clean and/or replace your vent ducting from the wall all the way to the vent opening outside. In addition, while you have the dryer open THOROUGHLY clean the inside as well. This includes the air baffle where the blower fan is located. Rule of thumb: if you have lint INSIDE the dryer, it's clogged somewhere. Good luck and I hope this helps you.
Sep 22, 2007 | Dryers
Whirlpool LER4634J Electric Dryer Logo
122 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
