Question about Sony KDL55NX720 3D LCD TV
Why does it powers on for about 3 seconds and powers back off and red light blinks 4 times
    Top Expert:
  • Sony Master
  • 74,383 Answers
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on May 07, 2014
circuitcity
  • 137 Answers
SOURCE: power button
This is a very simply fix. Your problem is you have a bad thermal fuse. This fuse can be found in the Lamp housing. You need to take the back off in order to fix this problem. Replacing the thermal is not hard, but you need to be a little handy. Part number 1-910-023-93 Average cost $9.00
Posted on Dec 07, 2007
  • 86 Answers
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Posted on Mar 25, 2009
  • 89 Answers
SOURCE: red standby light blinks 4 times; no power
I will forward a link to a page where you can get more information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467
Posted on Jun 18, 2009
SOURCE: tv shuts off spontaneously. red power light blinks.
re: sony flat panel lcd tv mod. # klv s 40a10.
No power. When power button is pressed, nothing happens.
The stand-by at the power supply ( cn6201) measures to be 3.47 v. instead of 5 v. However, when I unplug cn6201 (5 pin connector) I can read 5v. at the power supply.
Any suggestions?
Posted on Aug 29, 2009
  • 8909 Answers
SOURCE: I have sony Bravia KLV
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Posted on Mar 09, 2011
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
Replaced bulb in kdf-50e2000- when powered on green light flash 3 times & fan engages, 2 seconds later fan quits and i get a 3 red light blinks
impossible to actually see if lever is Fully engaged---with door off try to engage with a match stick or something not metal--see if set comes on that way.
Apr 20, 2012 | Televison & Video
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
Only comes on for a second power light blinks red 4 times, stops then repeats
4 times standby red light blinking is an error code that shows that Fan problem in tv. Check following possible causes of that problem in tv:
1- Fan 1-4 power is not supplied. (AGU board).
2- Fan caught wires or harnesses.
3- Fan connector is not attached securely.
Thanks.
Jul 23, 2010 | Sony KDF-E42A10 42 in. LCD Television
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
HP Compaq d530
it all depends on the number of flashes , pause, repeat.
Since the problem did not indicate any beeps her is the following info
Power LED blinks RED 2 times, one every second, followed by a
2-second pause. = Processor Thermal Protection Activated
3 blinks 1 second apart = Processor not installed (not an indicator for a bad processor).
4 blinks 1 second apart .= Power Failure (power supply is overloaded)
Other possibilities are:
Nov 07, 2007 | HP Compaq Business d530 Ultra-Slim PC...
Sony KDL55NX720 3D LCD TV Logo
53 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
