Question about Mitsubishi WD-65C9 65" DLP HDTV
White Dots appearing on screen - Mitsubishi WD-65C9 65" DLP HDTV
3 Suggested Answers
SOURCE:
  • 12 Answers
SOURCE: small white dots have started to appear on our
Your problem is that the DMD device is failing. You're in luck, though. Mitubishi has recently released a replacement DMD device in order to keep repair costs down for the consumer. Take your TV to an authorized Mitsubishi servicer for repairs.
Posted on Sep 30, 2011
SOURCE: White dots appearing on Mitsubishi 1080p DLP tv.
Actually you must replace the DLP chip that is buried deep in the works of the tv. Unfortunately this can run into a nice lump of change. Do what I did. Perhaps you've heard the old addage
Posted on Apr 25, 2012
Cracked screen & white dots appearing since the crack appeared
I have a Mitsubishi TV and had the same problem. There is a mirror that moves to control each pixel. When some of them fail to move you get the white dots. Google your problem and a company will come up(sorry forgot the name).,you can buy the new part from them and they have exact utube videos to help you do the repair. Took me about an hour. Part was around $150. Very rewarding feeling when you turn the tv back on with no white dots.Still dot free after two years
Mar 16, 2014 | Mitsubishi MBS73A Base for WD73C9 WD73837...
Lots of dots on the screen. In light areas they are black dots, in light areas they are dark dots
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years, and the price is USD200
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 27, 2014 | NEC Lamp for NP215 Projector
I have nec np200 and there's a lot of dots appeared on the screen. what seems to be a problem
I have 2 NP-200 projectors installed in a school which show white dots on a black background and black dots on a white background. This is caused by the DMD chip losing pixels. Only solution is to replace the chip, I'm researching now if that i an economical solution.
Oct 25, 2012 | NEC NP200 Projector
Dots
white dots on screen
Sep 17, 2012 | Samsung DLP HL-P5663W 56" TV
Many white dots appears on the screen of my benq w600 projector
Jacob, what element on the mainboard is the source of these dots? I have the same problem - it is only one dot now, but I think there will be more with time.
Also, the second question is: how do I unscrew the mainboard from benq W600+? I remoced the metal cover, unplugged all the cables, but there's something still not letting the board go.
Jan 29, 2012 | Office Equipment & Supplies
White dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Feb 06, 2010 | Televison & Video
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
Jan 28, 2010 | Samsung Televison & Video
I have white dots on the screen of my hsl4266wx/xaa?
If these dots are only seen when the picture is on I would look for the Optical Block to be causing it. Are the dots in the same place each time you turn it on?
Jul 17, 2009 | Samsung HLS4266 TV
White dots appearing on tv screen
Will need model number, but sounds like digi board problem
Craig www.classtorations.com
Mar 18, 2008 | Samsung PCL545R 54" Rear Projection...
Mitsubishi WD-65C9 65" DLP HDTV Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
