Question about Fisher and Paykel DE08 Gas Dryer
This is electric dyer. Wont Start.
I cleaned the lint from the whole thing, checked the breakers and plug. Still will not start. How to fix this. When I turned it on it made a clank and thud. Maybe broken belt? How do I tell? Is there a reset?
  • lisamoiles Nov 07, 2007
    Thank you hotuna. I called a repairman and the motor is shot. Only one year past the warranty, I will miss it , it was a great dryer.
    Sergeant:
  • 288 Answers
The clank and thud may have been the bracket with the wheel on it hthat keeps the belt tight. when you shut the door and push the start button what happens?
Posted on Nov 05, 2007
My Samsung dryer DV2C6BEW/XAA will only run for 10 minutes then shuts off and wont come back on for 20 minutes and I have no codes
Your dyer has several "overheat" switches or thermostats built in to prevent overheating and possible fire. You will be needing to "tear the whole thing apart" to find the problem. Start with the air ducting. Easy way to check it is to disconnect the hose from the back and see if it still shuts off too soon. If it does not, your vent to the outside is plugged and is causing the problem. If it still happens, you will need to clean the whole machine of accumulated lint by taking it all apart. Big job.
Then try it. If it still misbehaves, you have a bad "fuse" or "switch" inside the back or the bottom. There are as many as 6 on some models. An electrical tester will help you find the "tripped switch".
Be blessed.
Sep 01, 2013 | Samsung Dryers
My fisher & paykel model ad39 dryer has stopped working
Always unplug the appliance before working on it.
I would suggest checking the circuit breaker in the breaker box for your apartment, to see if it has tripped. You have probably already done this, but try to reset (open all the way and then close) the circuit breaker. Plug the power cord in again and try to operate the dryer.
If it trips the circuit breaker again, there is a short circuit or a ground, and you should unplug the machine and diagnose the problem. 240 volts AC, when shorted or grounded can start fires or kill people.
Many Dryers are equipped with a "non-resettable thermal fuse". When the air being blown through the dryer gets too hot, this thing melts and opens up the entire power circuit.The dyer doesn't do anything, as if it had no power.
This non-resettable thermal fuse can usually be purchased from the manufacturer or a good appliance supply store, and comes in a kit which also includes a new thermostat, to replace the one that probably failed and overheated the machine to start with.
Get a friend who is an Electrician to help you if you are at all unsure of replacing parts in your power circuit. Be sure to unplug the machine / use a VOM to check it dead before you touch anything electrical. BE SAFE. 240 Volts AC is not just playing around.
Oct 06, 2012 | Dryers
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Maytag Performa Electric dryer. Went to put in load and start-would not turn on. Checked breaker first. Then listed and I could hear the timer clickin on the front panel.Front door panel was full of lint....
In-laws machine did exactly the same thing. Check the thermal fuse.
Turn off the breaker.
Pop the top open with a flat screwdriver (there are two clips at the front)
There are two white wires on the right-side of the burner element, this is the thermal fuse (wires are kinda awkward to remove)
I jumpered these to wires and it started right up.
Jan 25, 2010 | Maytag PYE2300AY Electric Dryer
G.E. electric dryer terminal block and wires are burnt. I took the dryer apart to clean the inside of dust and lint. I put it back together and plugged it in. The breaker tripped,and I looked at the...
you did not say how old? but I find that all it takes is one wire to get old, and starts to heat up because electric cant flow through it, then it gets worse and worse fast, then heats up the whole block, till the whole thing gets melted...bad thing is its happens slow enough that the standard 30 amp breaker won't trip during this slow melt down!
Mar 13, 2009 | Kenmore 64902 Electric Dryer
Dryer wont work!
A couple suggestions: (1) The switch in the front may be bad. It's the switch that turns the dryer off when you open the door. (2) Make sure the door latch keeps the door shut. If it is worn and the door isn't shut tight, the switch will not let it start. Hope this helps.
Oct 15, 2008 | Whirlpool LER5636P Electric Dryer
Dyer on combo won't start
This could either be a bad start switch or door switch
May 29, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Fisher and Paykel DE08 Gas Dryer Logo
180 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
