Question about Nikon D3000 Digital Camera
Nikon camera blank screen problem
Camera screen is blank,only camera info displays, i cant see anything through the lense, not even images on memory card snapped before the problem occured
  • 6 Answers
SOURCE: Screen
Get on to Nikon and let them know about it, it is a common problem with the S4. They are fixing the 3500 and others for free.
 John.
Posted on Oct 16, 2007
  • 13 Answers
SOURCE: Nikon Coolpix l6
With the power off, hold the camera in your palm and smack the front of the camera on your leg or arm. You might have to smack it a few time to get it to work. It has to do with the camera CDD lense (shuttle) being stuck. By smacking it around, it will free up the lense. Being extra gentle with it though. It worked for me. Hope this help.
Posted on Nov 11, 2007
SOURCE: Bought a new memory card for my nikon coolpix 3100 card wont work
It is too big. 1G is max for the 3100.
Posted on Oct 16, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: FOLDER CONTAINS NO IMAGES.
Please follow the instruction below and let me know what is happening.
1. format the new card.( Can't format is from any virus
infected PC ).
2. Insert the card then reset your camera setting.
3. select your mamory card default for save the
photographs.
4. Before start photography confirm that your battery
is fully charged.
Thnaks & please give me feedback about your camera.
Posted on Feb 03, 2010
  • 10865 Answers
SOURCE: Nikon Coolpix s4-monitor working but no image
hello. you may be involved in a recall. please read this http://www.nikonusa.com/Service-And-Support/Service-Advisories/COOLPIX-Service-Advisory.page
please rate my answer as very helpful thank you. joe
Posted on Mar 01, 2010
Nikon s9300 - When I turn it on, the lense fully extends, but the screen stays black. I have to pop the battery out, then put back in for the lense to retract. Battery is fully charged and even tried
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Dec 21, 2013 | Nikon COOLPIX Cameras
Black screen
Sounds like your Sony needs a trip to the camera shop.
Jan 25, 2013 | Sony Cyber-Shot DSC-W530 Digital Camera
Hi K akima...have followed your advice, but no luck. When I go to continuous mode, it only lets me shoot a single shot, the display briefly reads r 08 then returns to r 09 again. I`ve tried my other lenses...
nikon r09,r11, etc . it mean memory buffer of your camera. memory buffer is a temporary memory for your captured images before it store to memory card.
if r00 it mean, you can't take a picture, even 1 picture... that because the camera buffer memory is full.
the number of memory buffer will also drop if noise reduction on
Feb 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Jan 17, 2010 | Nikon D80 Digital Camera
Cant capture photos as the screen does not display image.
May be issue is with Display LED..Please contact nearest service center...Check for the Warranty for free service
Thanks
May 31, 2009 | Olympus FE-20 Digital Camera
LCD has gone blank
Hi this is tech crazy
Based on the information you have provided, it appears that you may have
encountered this issue. To determine if the CCD (image sensor) is
working properly, please follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
four.
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service
Hope this solution helps you a lot
Please rate me on the above said solution
Feb 04, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
It doesn't take pictures...
Sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Nov 02, 2007 | Canon PowerShot A80 Digital Camera
Screen
 John.
Aug 31, 2007 | Nikon Coolpix S4 Digital Camera
Nikon D3000 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
