Question about 1 Cabin Furniture Old Wood Dresser
Remove handle Inside the drawers it looks almost like a Allen wrench but round. Can't find anything to fit
    Top Expert:
  • 3,698 Answers
Most auto parts dealers have all kinds/shapes of socket type screwdrivers.
Posted on May 07, 2014
I have a single -handle Moen Torrance 87480 kitchen faucet that needs the cartridge replaced. (I had Moen ship it to me.) My problem is, I can't remove the single handle using my 3/32 allen wrench. When...
Should be coming out if head not stripped or threads inside at set screw aren't stripped. Can you tell at all with perhaps flashlight if set screw is turning at all? Look like it backing out?
Jan 30, 2011 | Moen & Replacement Cartridge
I have a leaky faucet. I've shut the water off, removed the chrome cover over the control stem handle, but I'm stumped. How do you remove the brass fitting that holds the control assembly in place? I don't...
Normally there is an allen wrench that unscrews to allow the top to come off the control valve you can go to a home depot and show them the vavle repair you have to get the right allen wrench if you don't have the right one. normally they are 1/16 of an inch in diameter.there are three O-rings that can leak the barrel O-ring 2 of them and then the small o rigs for allowing the hot or cold to come out of with a spring on the inside of the barrel. let me know if you need more help.
Jul 04, 2010 | Hansgrohe 32020001 Talis S Single-Hole...
How do i remove exterior handel from door?
put ur head inbetween handles really close and open door fast , lol just playin no but look on inside upper and lower of handles might be easier if open door and u will notice an upper and lower allen wrench set screw inside just have to find the right allen wrench that fits that and just loosen each one enough until handl comes off... hope this helps let me know
Apr 08, 2010 | GE Profile PSW26P Stainless Steel Side by...
Trying to disassemble Ladylux Cafe faucet. Grohe
If it is just replacing the handle you will only need a smaller screwdriver set (pretty common) and an allen wrench. I don't know exactly what size you need but you can get a set of these wrenches pretty cheap at any tool or hardware store. Basically the tool is a hexagonal rod that is bent in the shape of an "L". You'll need the smaller set for this job sold usually in sets that have a range of sizes from .05" to 3/8" diameter. I would guess your hex nut is 1/8" or less.
On the bottom of the handle between the sink bed and the handle you'll be able to feel a small hole. When you stick the allen wrench in there it should fit snuggly if the allen wrench wiggles a lot go to the next size up. Since the screw is facing up you will pull the other end of the wrench toward you. This will loosen the screw. It will not take a lot of effort so if you have to force it make sure the allen wrench is actually seated. Kind of a pain but you'll have to reposition the wrench as you get it loosened to fully extract the screw.
Once the screw is out the handle will drop down and the cap just pulls off. Assembly is reverse but make sure that your screw is going into the threads without resistance before tightening. This will prevent cross threading.
Feb 15, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
How do you separate the handle from the faucet. Americian standard Gold faucet.?
On the underside of the handle, all the way back on the round part there will be a hile that is sometimes covers with an little cap that you need to pop off with a knife or a small screwdriver. In that hole is a set screw that you will need an allen wrench to loosen. An allen wrench is a six sided peice of metal that will fit into the six sided whole in the set screw. Different handles will take different sizes, so you will have to find the right size to fit snuggly into the set screw hole.
Loosen the set screw and then you should be able to lift the handle up and off of the stem.
Hope that this helps you to solve your problem.
Thanks for using Fixya!
Heatman101
Nov 21, 2009 | American Standard "Ceramix" Single Handle...
I have a ksbp25fkss side by side fridge and the door handle on the freezer is loose, but the handle is not the one depicted in the manuel. the handle must be tightened from the back or inside of the door....
you should have trim below and above the handle if not then and its a stainless steel door then there is small round opening on the side of the handle you'll need allen wrenches once you loosen the allen the handle slides up or down then you will be able to tighten the stud post screw then reverse the mounting -----------------be cautious of scratching the stainless steel door when removing the handles
Sep 01, 2009 | KitchenAid KSCS25FKSS Side by Side...
Moen Posi-Temp Shower Handle removal
I hate to say this but maybe the inside of the allen screw has been rounded out by a previous worker. You can drill the screw out and replace the handle with a new one. NOTE: Moen replacement parts are not cheap!
Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Refrigerator door handle is loose
If allen screws are there then that is what holds handle in place. There are screws that the handle fits over, so remove handle and tighten as needed. Allen screws are very tiny.
Nov 27, 2008 | LG Refrigerators
How do I fix loose handle?
havnt worked on that but... most times theres a cap or piece that will come off hiding the screw not sure what yours is cant find anything on it .. hope that may help some
Sep 02, 2007 | GE Monogram ZDWC240NBS Stainless Steel...
1 Cabin Furniture Old Wood Dresser Logo
483 people viewed this question
Top 1 Cabin Furniture Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a 1 Cabin Furniture Furniture Expert? Answer questions, earn points and help others
