Question about Evinrude Johnson OMC 0582508 - Ignition Coil
Can you check to see if its good or bad? - Evinrude Johnson OMC 0582508 - Ignition Coil
    New Friend:
  • 19 Answers
An Ohm's meter is the best way to tell you if it's bad, obviously no reading at all means it is open ( BAD ) too many Ohm's and it is shorted out ( BAD ). Of Course there is the old fashioned way of testing it. But it doesn't feel very good so I do not recommend it ( apply 12 Volts DC power and wait to see spark ).
Posted on May 07, 2014
Is there a fuel pump reset button on this car ,if so wheres it at?
no reset start by checking ignition key if its worn down vehicle wont recognize it also is key an electronic key may have gone bad if good recheck fuses if good pull fuses and check for power if good recheck relay if good pull relay and check for power if good than check lines and connections and power at pump connections if good than pump bad if anything bad leading up to pump repair replace and recheck connections up to pump also check battery connections for corrision
Jun 02, 2015 | 2007 Pontiac Grand Am
NO LOW BEAM HEADLITES FUSES GOOD BULBS GOOD
this could be a bad ground. Check all connectors for burns or loose conections and go ahead and change the fuses. they may appear to be good and be bad.
Jul 13, 2014 | 2005 GMC Envoy
Abs light, park brake, showing up
Hello. ABS can have problems and cause them. Check the brakes out first to see if they are good or bad. Then check ABS Sensor to see if they are good or bad. If ABS Sensor's get bad or become bad, they can cause big problems to the whole braking system. Good Luck.
Jun 04, 2014 | 2005 Ford Futura
I have a 02 rsx type-s, my check engine light is flashing and solid at points, but always on, when i had a scanner to check the code it gave me misfire in all 4 cyclinders, i changed the spark plugs a
misfire in all 4 cyclinders hmmm...... compression tester check compression 125psi is good 100 and lower is bad (head gasket they go bad) if that is good, do fuel filter,, or charge system is bad, or bad ground or bad coil
Feb 12, 2013 | 2003 Acura RSX
Car died, won't start. check everything, all seems to be working right, could the computer be bad?
you will have to have it scanned with an obd11 scanner. if the coputer is no good it sends the appropriate code.the days of mechanics are all but over,
you have to be a technician these days.good luck and have a happy holiday.
Dec 15, 2011 | 2001 Volkswagen Beetle
The driver side window will not go up or down on a 1999 honda passport.is there a way to manuelly make them go up.is there a quick way to check the relays?thanks
There is not way to manually raise the window. First check the fuse. If the fuse is good then remove the door switch and see if the switch itself is bad. If it is good then the relay is bad or the motor is bad. Check the relay by replacing it with a known good one.
May 16, 2011 | Honda Passport Cars & Trucks
I have a 2002 Oldsmobile Bravada and the wipers will not turn on can you help me
1. check if the fuze is bad
2. If good check for voltage at the wiper motor
3. voltage good Bad motor
4. no voltage bad switch hope this helps
Aug 20, 2010 | 2002 Oldsmobile Bravada
Horn is not working
First check the fuse. Then check wires to horn which would be close to the radiator on drivers side. If the wires are good and fuse is good, then either the switch in the steering wheel is bad, or the horn is bad. You can test power to the horn with a voltmeter. If there is no power, and fuse is good, then the switch is bad.
If there is power to the horn and horn don't work. Then horn is bad.
Jun 16, 2010 | 1996 Dodge Caravan
Blower motor and turn signals stopped working
CHECK BLOWER MOTOR FUSE AND RELAY.IF ALL IS GOOD.CHECK TO SEE IF BLOWER IS GETTING POWER.IF NOT.SWITCH IS BAD.IF YES REPLACE BLOWER MOTOR.IF TURN SIGNALS STOP WORKING.CHECK FUSE FIRST.IF FUSE LOOK GOOD. CHECK BULBS TO SEE IF THEY ARE BLOWN.IF BULBS LOOK GOOD PROBLEM COULD BE WORN OR CORRODED BULB SOCKETS OR.BAD GROUND.OR THE TURN SIGNAL SWITCH IS BAD.
Aug 24, 2009 | Plymouth Voyager Cars & Trucks
Evinrude Johnson OMC 0582508 - Ignition Coil Logo
76 people viewed this question
Top Evinrude Johnson OMC Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Evinrude Johnson OMC Boating Expert? Answer questions, earn points and help others
