Question about Kenmore Sears Dryers
Dryer made a loud pop and there was burning smell and now dryer does not go on. It is an old dryer but a good one. Is it time to buy a new one?
    Problem Solver:
  • 11 Answers
Is always better if you have a service tech come in and give you his honest opinion,
there are several things that need to be seen.
Posted on Dec 23, 2015
SOURCE: Burning smell
We had the same problem. After we used it a few times, the smell went away.
Posted on Sep 07, 2008
aborcass
  • 2651 Answers
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
TheMobilian
  • 8220 Answers
SOURCE: Smells like it's burning and smoke coming out of chimney vent
Get the filter housing out of the machine and wash it out. Blow out the blowers housing. Change the control thermostat.It mounts right next to the fuse on the back:
Posted on Dec 16, 2008
kachbibi1
  • 979 Answers
SOURCE: LOUD NOISE AND BURNING SMELL
How old is this dryer? If it is older that 15 years get a new one. You don't want to deal with the headaches. The motor may be going bad on it and the wiring could be melting. I assume it is not working now. Have him check the breakers. Make sure the connections are o.k. in the back. Clean out the lint piping and look for lint underneath it as well.
Posted on Jan 14, 2009
  • 17 Answers
SOURCE: My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Posted on Nov 06, 2009
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
Have a 65inch Mitsubishi DLP. acouple years old, just heard a loud pop,smelled like it was burning,it turns on but just sound????
hi,
Check the lamp of you tv. The lam is burned. that's why you heared a pop up sound and burning smell. Just check it and replace it. you will get the picture back.
ok
Apr 16, 2011 | Mitsubishi WD65737 65" DLP TV
Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
Aug 18, 2009 | Frigidaire FEX831CS Top Load Stacked...
My hotpoint tdl34 electric dryer is working but not getting hot
heating element has blown. did you hear a loud pop at one time or a burning smell? If so this is the problem. You can find instruction and order the part you need on ebay to change the element. It is easier than you think.
Jun 07, 2009 | Hotpoint Dryers
Screeching noise and burn smell how do I open dryer to repair
Pull it out from the wall, unplug it and remove the back panel by removing the screws. The problem is most likely the belt around the drum which is either worn out or out of alignment. Take a look at it and decide if you can just straighten it on the drum or if you will need to buy a new belt.
May 01, 2009 | Dryers
Jan 13, 2009 | Maytag PYE2300AY Electric Dryer
Dryer stopped working
The dryers drive belt most likely broke. it must be replaced with a new one.
Dec 20, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Dryers Logo
Top Kenmore Sears Dryers Experts
Douglas Wade
Douglas Wade
Level 1 Expert
William Goodman
William Goodman
Level 1 Expert
Are you a Kenmore Sears Dryer Expert? Answer questions, earn points and help others
