Question about Ingersoll Rand Air Tools & Compressors
What causes a high airend temp and a t-1 failure on an IR compressor?
Problem is as stated. Tried cleaning out cooler as best as we can without complete dis-assembly but still shutting down. model number SSR-EP255E, Serial # KE249U95321
rockitman187
  • 2559 Answers
SOURCE: After removing and replacing a completely shredded
It sounds like you have a valve floating.
Posted on Feb 22, 2009
ollie reece
  • 1167 Answers
SOURCE: We have a SSR 20 screw compressor belt driven
are you in the uk bud
Posted on Nov 03, 2009
SOURCE: How do I obtain a service manual for the COMPLETE
not a service manual but a manual. To get the service manual you will have to contact the manufacturer, links in the manual www.iraindco.com/PDF/CENTAC/CENTAC.pdf
Posted on Mar 17, 2010
Testimonial: "Thank-you so vey much much. "
  • 210 Answers
SOURCE: SSR-EP75 Ingersoll Rand SERIAL # F15525U95286 320
Mike, an EP 75 Should not use more than 3 to 5 parts per million of oil. Your oil issue sounds like you have a separator that needs replacing or a plugged scavenge line. The separator is located in the oil tank. the scavenge line and orifice come from the bottom of the separator filter to and Thur the oil tank lid. then to the air end. In this line approx. 1ft from the lid should be the orifice. make sure its clean. your high air end temp can be from several different problems. 1- low oil level from separator or scavenge line plugged. 2- A plugged oil cooler. Dirt and debris pushed against the cooler by the the cooling fan. This needs to be cleaned using a pressure washer. Wash in the opposite direction of air flow. Be careful with the pressure washer. You can damage the cooler. Low oil level and dirty coolers are the most common problems when getting high air end discharge temp shutdowns. However you could also have a bad thermal valve located where the three cooler lines come together. you will have to remove one line and 4 bolts. inside is the thermal element. You may also have a bad HAT switch (high air end temperature). It is located in the end of the air end and simply unscrews. I do not know of any adjustment.
Posted on May 31, 2011
  • 33 Answers
SOURCE: 7.5 tas high airend temperature
1. Check your oil level, top up, or totally replace it
2. Check your cooler (Radiator looking thing) blow it out with a blow gun
3. Check your thermo valve (may need replacing)
4. Is the room that your compressor is in very warm, ambient air is a big factor in the running of your compressor
5. Do you have all the panels fitted to the machine? These are needed to aid airflow past your air-end
These are the main causes of high air end temperature. It may just need a good service
Hope this helps
Posted on Aug 30, 2012
Ingersoll rand compressor model no 75i high airend discharge temperature trip why
Wash the cooler first. Then replace thermostat if washing cooler d't take care of the problem.oesn
May 08, 2017 | Ingersoll Rand Air Tools & Compressors
IR 75I COMRESSOR AIREND DISCHARGE TEMPERATURE HIGH WHY
This problem could be due to several items. Low oil level, Bad temp.probe. Cooler stopped up or dirty and not allowing enough air flow thru it or maybe a thermostat. Also temp. in compressor area can be causing problem also.
May 08, 2017 | Air Tools & Compressors
What cuases high a/e discharge fault on ingersol rand air compressor
Dirty coolers are always associated with high discharge temps,always make sure your coolers are clean
compressor oil filters being clogged can also raise your temp n cause the unit to over heat,and on the much bigger machines if the compressor oil pump fails then you will have severe over heating as the oil flow to the cooler is assisted by the pump!!things like regulating pressure should always be adjusted to the machines specs so it doesn't over pressurize n put load on your airend while the engine is at idle.
Jun 24, 2014 | Ingersoll Rand Stationary Air Cooled...
Hope this helps
Aug 29, 2012 | Ingersoll Rand Rotary Screw Compressor ...
My air compressor show continusly the alarm NO CONTROL POWER
No Control power is often caused by high airend temp or a faulty High AirTemp. switch(IATS Switch i.e High Air Temperature Switch). I suspect the IATS switch is bad and opening prematurely/coolent level not suffecent or bad filter condition because the att. temp. probe located next to the switch is set to give a temp alarm and shut down the compressor at 228 degrees.The hat switch is located in the end of the airend and should have a 1/2 " flex conduit attached to it. When this switch opens it cuts control power and series to emergentcy switch having two NC connection but if press emergency it gives alram emergency but if you remove cable 36 inintellisys control pannel. Thus the controller issues a No control power . This switch is set to open at 245 degrees. If faulty it may open at 150, 180, 200. Anything but what it is set at. You can check this switch with a meter. When the unit trips simply test for 110 volts at the switch or in the control panel if familiar with wiring . please be very careful while in any electrical panel.. 110 volts in, 110 volts out. NO 110 volts out or on one leg of the switch means its bad and should be replaced.After it cools for a while the compressor will run again.
Jul 04, 2012 | Ingersoll Rand Air Compressor Maintenance...
Ingersoll rand air compressor model SSR-UP5-30-14 frequent trip on high airend temperature ....what is the solution ? and another unit ( same model ) always trip on " starter fault ". Untill...
check if approach and discharge pipes to oil cooler are similar temperature as there is a thermo bypass valve that controls the flow through the cooler if cooler is quite cool but still very hot inside this could be stuck in closed position causing restricted flow through the cooler
Sep 20, 2011 | Ingersoll Air Tools & Compressors
GX 11FF 270 10 Bar single stage Atlas compressor keeps going out on high temp, have done a full service and is still a problem
clean cooler fins and make sure the cooling fan comes on and it must get fresh air to run properly if it is in a small room without proper ventilation it will just keep circulating hot air and lastly if all the above are are met it maybe a bad temp sensor and make sure the unit has enough oil and the oil filter is not plugged and the thermo valve (thermostat) is not sticking best way to check this it to take the temp of each oil carrying pipe going into the cooler and the one leaving the cooler and see if there is a difference in temp using a ir temp meter
Jul 06, 2011 | Taylor Air Tools & Compressors
I have a 7-41 I.R. compressor. Recently serviced with 1200 hrs done. It now only runs for about 20 mins before shutting down. After 15 mins she starts again. I have tried bypassing water temp sender and...
make sure the cooler(s) are clean. Next check the airend discharge temperature switch commonly called a HAT (High Air Temp) switch. These switches will reset as the compressor cools down. I would be able to access the switch quickly. Run unit until shutdown remove wires and see if switch is open. if open you found your problem
Jun 01, 2011 | Ingersoll Air Tools & Compressors
I have a sullair ls - 120 we have been having problems with it getting hot and shuting off oil levels have been fine we have tryed different oil types we have took apart the unloader valve cleaned it and...
Get yourself a temperature gun and check a couple things:
1) Measure the oil injection temperature to the airend. This is a line going into the bottom side of the airend. 2) Measure the discharge temperature from the airend (this should be the same reading as the temperature gauge/readout on the compressor, but check to be sure)
You should get a temperature rise of about 25-30 degrees F over the airend. If you have more rise, you probably have an oil restriction: try an oil filter change.
If your oil injection temp is more than 160 degrees F or so, check the operation of the thermostatic valve. The thermo valve is a T shaped valve in the oil circuit. The oil line out of the bottom of the sump probably goes to a tee which splits flow to the cooler and the thermo valve. The oil goes through the cooler then to the other side of the thermo valve. The thermo valve should then mix the hot oil from the sump and the cool oil from the cooler to maintain the injection temp in the 150-160 degree range.
If you have cool oil coming from the cooler (should be maybe 140 F or less, and the injection temp is high, the thermo valve is bad. You can get a thermostat kit from your vendor to repair. If you've replaced the cooler, this thermo valve is probably the problem.
Mar 30, 2011 | Air Tools & Compressors
SSR-EP75 Ingersoll Rand SERIAL # F15525U95286 320 CFM i CONTINUE TO ADD OIL GOES OUT ON HIGH AIREND TEMP. SOMEONE TOLD ME THERE WAS AN ADJUSTMENT FOR THIS. CAN YOU TELL ME WHAT TO...
Feb 12, 2011 | Air Tools & Compressors
Air Tools & Compressors Logo
42 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
