Brother mfc error codes
Cc4-202-00000008
Mix-it-up
  • 832 Answers
SOURCE: Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Posted on Oct 23, 2007
  • 320 Answers
SOURCE: error 2001 on brother mfc 7420
please tell me more! i just checked my brother manual and i do not see a error code 2001????????????
Posted on Feb 16, 2009
  • 37 Answers
SOURCE: Machine Error 71, Brother MFC 8440
The problem is in the scanner motor.To cancel the trouble status follows these steps:
STEP1 .Press MENU *,2,8,6,4
STEP2.The machine beeps for approx. one second and displays “MAINTENANCE" on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
the machine is ready to accept entry from the keys.
STEP3.Now you are inside the simulation Press 01 to reset the trouble status.
STEP4.To exit the simulation press 99
Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine
exit from the maintenance mode, restoring it to the standby state.
Pressing the Stop button after entering only one digit restores the machine to the initial
stage of the maintenance mode.
I hope that this will cancel the error but if not canceled you should call the authorized serviceman to fix your machine.
Posted on Mar 01, 2009
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
Brother MFC 290C error cc3-003-00031c0e
Is this error shown on the computer screen or the mfc 290?
it doesnt look like a brother hardware error code. it looks more like a software crash error code.
try uninstalling all brother software, restarting your PC and reinstalling your brother printer drivers and software. (from original disc if you still have it)
If you still have problems you will most likely have to take both your computer and printer into a computer store for service.
Oct 09, 2014 | Brother Office Equipment & Supplies
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
Have an Error 51 on Brother MFC-210C all in one printer?
I can help you with your Brother MFC-210C error 51 problem.
Error 51 refers to a paper jam error.
Clear the paper jam to clear the error code.
If the error code will not clear after clearing the jam, resetting and powering off, the printer may require service.
I hope that helps.
Aug 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
How do I fix a machine error 78 on my brother MFC 8300?
unfortunately that specific error is pointing to a problem with the thermistor. here is the error code from Brother:78 Heater thermistor harness disconnected or broken. - SOLUTION: REPLACE FUSER UNIT
HERE is a link to other error codes and possible solutions.
Aug 30, 2010 | Brother MFC 8300 Laser Printer
MFC 3420C. I am getting error 41
While there are many ways to prevent Brother printer error code "41
Jul 11, 2010 | Brother MFC-3420C Printer
Error 46 on a Brother MFc-8840DN
According to the Brother MFC 8840DN manual:
Machine error code xx: MFC has a mechanical problem
Solution: Call Brother customer service and tell them the error number
USA 800-284-4329
Remember to rate users who offer their expertise to you at no cost :)
Sep 29, 2008 | Brother Office Equipment & Supplies
Error code cc3-205-03031f02 will not scan
What model do you run? Is it a brother mfc 240c or something diffrent?!!
I ve never seen such an error code for brother mfc 240c printers!
Dec 27, 2007 | Brother Multi-Function Center MFC-240C...
Oct 23, 2007 | Brother MFC 420CN All-In-One InkJet...
BRother printer error code 41
The printhead is defective. Call brother hotline. Because this is a very common error (due to malconstruction on the mfc 3820 ) they might replace it for free. And when asked: OF COURSE YOU HAD ALWAYS RUN THE UNIT BY ORIGINAL INK CARTRIDGES!!!! :-) (take the ink carts out before sending or giving it to a service dealer!)
Oct 14, 2007 | Brother MFC 3820CN All-In-One InkJet...
11 people viewed this question
jasbo
jasbo
