Sylvania tv shut off when you turn it on it immediately shuts off
4 Suggested Answers
  • 19 Answers
SOURCE: tv shuts off immediately after turning on
Does it shut off shut off, or is there audio present after the lamps shut off? When you shine a light to the screen do you still see picture kind of?
If still see picture, it's inverter/power supply or CCFL bulbs itself. If no picture, completely off, it's DEFINITELY the inverter/power supply.
Posted on Dec 08, 2009
  • 1212 Answers
SOURCE: Sylvania Model 6632LG shuts down
Check power supply board and inverter board for faulty solder connections and visually inspect electrolytic capacitors for signs of stress or failure. Bulging tops, black or brown crusty material oozing out of them, are the most common. Replace those that are visibly faulty with high ripple current types.
If that does not resolve it, the next step is to test the transistors in the 24 volt section and inverter section primarily. Recapping the power supply 24 volt section is prudent regardless of physical appearance of the electrolytic capacitors.
Posted on Feb 07, 2012
gravity1190
SOURCE: TV turn on screen turns blue then immediately shuts down
Olivia tv. 237-T12
I had the exact same problem. I can tell you how I successfully fixed mine.
I replaced the capacitors on the power supply board that looked even slightly overheated.
The plastic appear slightly shrunken.
None of these capacitors read bad after I removed and measured their capacitance.
So I cannot nail down a specific cap, but the tv is fixed, no more shutdowns.
IMPORTANT:
These circuits are designed to over heat the caps, they are placed too close to the heat sinks.
These tv are so big that (so much real estate) they could have easily made the board a little bigger,
so the caps are not so close to the heat sinks,
but then they would not sell as many tv, the tv would last too long.
Make sure:
1) Make sure that new caps are high temperature, at least 105 degrees Celsius caps.
I used caps of a little higher voltage rating than the originals.
2) Do not cut the leads, use the full length, so the caps will stick up about an inch out of the board.
position the caps as far away from the heat sinks as possible when soldering them.
This will look ugly but who will see them after you put the cover back on the tv??
c86, & c20 470u 35v
c39 10u 50v
c79 47u 50v
c69 4.7u 50v
c81 2200u 10v
c79 47u 50v
c74 10u 50v
This solved the problem.
regards.
rucko.com
Posted on Aug 05, 2012
Turn on and it immediately turns off
Sounds like component heating shutting power supply down possibly caps , if not completely electronics literate seek an engineer . Look on line for your model and most likely if this is a common fault it will be listed .
Jul 02, 2015 | Sylvania Televison & Video
Tv shuts off after 10 seconds
one of the energy cables is damaged, so tv 'safety protcol' turns on, not to burn shuts off.
go to service
Apr 18, 2013 | Sylvania 6427TE 27" TV
How do I fix it?
I'm having the same problem with my RCA. I was told it is probably a loose ground wire. GOOD LUCK
Jun 30, 2012 | Sylvania LC370SS9 LCD TV
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Sylvania 6432TD turns off within a second of turning it on
Had same problem Sylvania SRT2232s 32"had to keep powering on and off until it warmed up enough to finally stay on. Problem was the 100/50 & 1/50 filter cap took it to local repair total cost to fix was 74.52 works better than ever
Mar 06, 2010 | Sylvania SRT2232S 32" TV
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
Sylvania 6419TC
My Sylvania T.V. turns on and then it turns off by itself. It only stays on for onr minute.
Aug 10, 2008 | Sylvania 6419TC 19" TV
Sylvania SRC21134
This could be a High- Voltage shutdown circuit problem. The reason it will stay on longer with a bright picture, is the high voltage is slightly reduced, not allowing the shutdown circuit to shut off the set. But I believe your problems to be in the shutdown circuit.
Jan 03, 2008 | Sylvania 6413TC 13" TV
TV Dilemma
you have a stuck vhs tape in it.
Oct 20, 2007 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
