Question about Caterpillar C15 Acert Engine Wdisplay Standdiecast
Backfiring thru exhaust
Replaced broken inj rocker arm, set overhead, now backfires thru exhaust when running
  • Guy Dempsey
    Guy Dempsey May 07, 2014
    its just a c15 accert cat engine, the real mc coy
    Problem Solver:
  • 19 Answers
Valve Lash is incorrect, can also be caused by injector fallout ( injector over heated and continues to dump fuel long past its cut off point ).
Posted on May 07, 2014
Exhaust backfire
Check the following: 1. cracks in the distributor cap. 2. Ignition timing and advance 3. plug wires and plugs could be bad. 4. If carbureted- the power valve might be leaking. 4. Valve rocker arms over or under tightened. 5. vacuum leak. - check with a gauge. 6. Cam timing off.
Apr 15, 2014 | Vehicle Parts & Accessories
4 brl rochester carb
Backfiring is caused by either the firing order being incorrect or the engine timing is incorrect. generally backfiring through the carburetor is caused by incorrect firing order. confirm the distributor is inserted properly and double check firing order beginning with cylinder number 1.
Mar 22, 2014 | 1984 Buick Regal
Triumph herald backfires
check the vacuum hose to the carbies There is a hose that controls the plungers in the carbies
Nov 07, 2013 | 1988 Ford F 150
Backfired then quit
sounds like your exhaust valves aren't opening up which means either your cam is out of round, push rods are bent/flatten rocker arms broken, broken valve stem/seat, hopefully just the valve got stuck closed due to carbon build up
Jun 01, 2013 | 1992 Pontiac Grand Am
Briggs & stratton mod. 406777-0115-E1 engine backfires thru exhaust
This is a true tale sign of a valve being out of adjustment or possible burnt or sticking. Most likely its just out of adjustment. Setting them to Book Specifications of: Valve Clearance (cold) IN and EX .005" (0.13 mm) should take care of the problem. Since you said that it runs fine rules out the possibility of a sheared flywheel key, though I have seen one run with it slightly sheared. Thanks; George
Apr 22, 2013 | Briggs & Stratton Garden
1993 chevy corsica backfires
I think you have a valve problem. Need to remove valve covers and look for loose or broken rocker arms. If an exhaust valve does not open because the rocker is broken the trapped combustion gasses will revert through the intake when the intake valve opens. This can interupt the intake flow to other cylinders and prevent starting.
Nov 27, 2011 | 1993 Chevrolet Corsica
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
1999 500 Sportsman ATV Runs and idles fine, when excelerating backfires and won't rev up.
mine does the same thing chances are that your exhaust lobe on your cam shaft is wore out and also the exhaust rocker arm as well causeing it to back fire into the carburator
parts about 500.00$ labour I dont know
Sep 09, 2010 | Polaris ATV
22 hp. Kohler engine has new push rods and rocker arms and 1 new exhaust valve. engine is getting fire through spark plugs but will not start. backfires sometimes when you first hit the key, but will not...
check the valve lash sounds like you have them adjusted wrong, put the piston top dead center, with the rocker arms level with each other before you set them
May 23, 2010 | Garden
Backfireing
Hi
Check for bent push rods or broken or worn out rocker arms.
Apr 01, 2009 | 1987 Chevrolet Suburban
Caterpillar C15 Acert Engine Wdisplay Standdiecast Logo
281 people viewed this question
Top Caterpillar Toys Experts
fordexpert
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
