Question about ASUS Computers & Internet
Bios check sum error - ASUS Computers & Internet
    Brigadier General:
  • ASUS Master
  • 3,400 Answers
JUST CLEAR CMOS.
Posted on Apr 07, 2015
  • 70 Answers
Replace ur cmos battery
Posted on Apr 05, 2015
Benimur
  • 6966 Answers
SOURCE: bootblock
This messages indicates that the BIOS could not be located and loaded up. Normally this happens when the BIOS is corrupted. The corrective action required is to re-flash the BIOS using a DOS bootable diskette in the 1.44 FDD. Aside from the BIOS file, a flashing software is also needed. Pls start here.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 22, 2008
SOURCE: bios rom check sum error (report)
may be your os is correpted
Posted on Mar 17, 2009
ihavsolution
  • 152 Answers
SOURCE: bios check sum error
you need to change the CMOS battery which is located on the motherboard...
Posted on May 27, 2009
  • 5 Answers
SOURCE: EP-8RDA3I bios error problem with flashing bios
The file could be corrupt.
Re-download and try again.
Posted on May 14, 2010
Madmatt2006
  • 29 Answers
SOURCE: Error code reads "Cmos Check sum error-default
You need to fit a new bios battery a cr2032 normally
My tech team and I can help lots with PC stuff it would begreat if you could ask any PC questions you have here so we can guide youthrough it and discuss it properly http://www.mypcmates.com
Posted on Nov 05, 2010
Drive A media error bios checksum error
your current bios is corrupted since the check-sum that was generated when your bios eprom was flashed with your current bios version doesn't match the check-sum that is generated as now, meaning that your bios changed for a few bits. you can fix this problem by re-flashing your bios with a good ROM file that you can download from your computer maker site or your motherboard bios maker site, also upgrading your bios with a newer version will take care of the issue as well.
Mar 07, 2011 | Computers & Internet
Nov 05, 2010 | Biostar GEFORCE 6100-M9 Motherboard
Just bought this Samba 1845 system. Upon power on receive bios rom checksum error, insert system disk. Is the battery dead, bios need to be flashed again, please help
A BIOS sum check error is usually due to a near flat BIOS battery.
Replace the BIOS battery and configure the BIOS Date & Time setting etc.
Oct 27, 2009 | FIC Samba SM-1845 (SM1845GV) Barebone
When i'm turn on my pc this message would appear ''bios rom chesum error'' what should i'l do?
the ram has some error
better remove the rom blow air to it wipe it wit a clean soft  material
then replace the same
Mar 06, 2009 | Computers & Internet
there may be problem with *********** board get it repaired. there is also a chance of battery not working (even the new one)
Dec 18, 2008 | E-Machines eMachines Desktop PC
Your bios defaulted. The battery keeps: date, time, and bios settings. You need to get in your bios and change the settings to what they need to be. You can enter the bios by hitting DEL during boot.
Dec 18, 2008 | Computers & Internet
I am getting 1 long beep and then 6 short ones
Hi canturob,
When a system reports a check sum error the bios is telling you the information stored from the last working boot does not match the current settings stored in the bios. Please power down your MSI system, unplug the power cord. Open the case & clear the bios. Location of JBAT1 on page 3 in manual.
Clear CMOS Jumper: JBAT1 page 10 in the manual. Remove the battery/cmos. Check it's voltage with a volt meter. It should test to 3volts DC. Anything less & the battery needs to be replaced.
While in the case re-check all data cables & power cables for good connection.
The MSI board uses the Award bios. Your current beep code of 1 long & six short is not a common beep code for the Award bios. See bios beep codes here: http://www.bioscentral.com/beepcodes/awardbeep.htm
If the battery checks out ok, you may need to update the bios. Go to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=utility&maincat_no=1&prod_no=205
To update your MSI bios (Option only if bios clear fails to resolves the check sum issue).
Good luck canturob!
Mike
Dec 03, 2008 | MSI PM8M-V Motherboard
Bootblock
Oct 22, 2008 | MSI K9VGM-V Motherboard
Check sum error denioted in win xp
you internal cmos battery is flat needs replacing. then reset time and etc in bios
Oct 10, 2008 | Televison & Video
Computers & Internet Logo
85 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
