Question about Akai XR20 Beat Production Station
I own akai xr20. i set it back to factory settings i thought. i have no sound coming from either jack. please help me
. No sound from either jacks. Tried setting back to factory setting. No sure it did. Please help.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
Goto device manager/ audio icon/ click it automatic update. step by step...
Posted on May 17, 2014
I can't get sound on my akai tv. Picture comes on just fine. Just hooking it up to my DVD player. Please help!
speakers might be blown? buy some computer speakers and use the headphone jack
Apr 12, 2017 | Akai Televison & Video
Only two front speakers are working
http://safemanuals.com/user-guide-instructions-owner-manual/AKAI/CD3000XL-_E owners maual ......... you need to change the settings on it for suround sound
Oct 21, 2008 | Akai DHT300 System
Hello - I have an Akai TV - Model # PT52999HD, Serial # 39ZY150875N - and the picture works well, but there is no longer any sound. Can you advise me of a possible problem and what I may do to fix it?...
Let verify first to narrow down to where the problem can be. First, make sure the MUTE function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 10, 2010 | Akai Televison & Video
No audio on tv?
Aug 01, 2010 | Akai LCT2715 27 in. LCD Television
Sound went out?
Unplug,replug the tv about an hour later.Let the tv to reset it self back to factory setting.Go in ur tv menu go to AUDIO setting.Go down to reset.Now ur tv should have sound back.No,sound after the reset.Than ur tv Tuner board is dead,require changing the Tuner board.
May 27, 2010 | Toshiba 32AV502U 31.5 in. LCD HDTV
I own an akai XR20 drum machine. Was using it and the thing froze. The toggle still changes the bpm but nothing else works, and the (a) button is not flashing, though all else is lit. please help!
If you were in Record mode and forgot to press stop it will loop continuously until you do.Try holding Pattern/Song and press Play to see if it will play the demo song. What does the display LCD say? Are you stuck in System Setup mode?Are you stuck in Record Setup mode? If the record button is not flashing you are not in Record mode.Have a look at page 15 in the manual and see if it will go into Pattern mode. I forgot to ask you if you have a manual. If not you can download one here:http://www.akaipro.com/contentmgr/showdetails.php/id/1163/tt/5 The reason I asked you about the footswitch is that when you power up the XR20 checks the footswitch jack to see what kind of footswitch you are using. The manual unfortunately doesn't mention what would happen if the jack failed. This can happen sometimes when a cord plugged into a jack gets kicked. The solder joint between the circuit board and the jack fails rendering the jack non functional. I also didn't ask you if you are using batteries or the correct power supply. Try describing to me what the display says. Let me know if any of this helped.
Nov 28, 2009 | Music
No sound coming from one of the jacks
Please check if your sound balance is in the middle
also try to insert the jacks properly
hope this solves your problem
Jul 16, 2009 | Philips Audio Players & Recorders
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
TV has no sound
Just a thought...does the set have a headphone jack? When you plug in most headphone jacks it disables the internal speakers. If it does have a headphone jack trying plugging in some headphones to see if you have sound there. If you do, plug/unplug it a few times...worth a shot.
Nov 18, 2007 | Philips 25PS40S 25" TV
Akai XR20 Beat Production Station Logo
105 people viewed this question
Top Akai Computers & Internet Experts
Michael Vincent Cruz
aravind shet
aravind shet
Are you an Akai Computer and Internet Expert? Answer questions, earn points and help others
