Question about HP ProCurve 224M (J3299A) Networking Switch
How to factory default Procurve 224M J3299A using console and/or Reset/Clear
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
There's a reset button on back. When pressed in a specific pattern the switch is returned to the factory default configuration. Chapter 8 discussed this in the following manual:
ftp://ftp.hp.com/pub/networking/software/59672145.pdf
Posted on Aug 20, 2014
3 Suggested Answers
  • 624 Answers
SOURCE: Help with hub Procurve Hp j3294a
These are non-manageable switches, not configurable thus no IP. You should be able to plug it in to your home wiring, however, if you don?t have a server or dhcp server you will have to assign IP addresses to your computers and other network devices manually.
Posted on Jan 01, 2007
SOURCE: I want reset the factory
To reset using the CLI, run the command "erase startup-config". When prompted, say yes to reboot and that will restore the procurve switch back to factory settings after it starts up.
Posted on Mar 08, 2011
How to reset xbox settings
If you are resetting to factory defaults use the system settings, go into storage and use the "y" button to clear the cache of all settings, if you are resetting the entire console there should be a restore to factory default button on the bottom of the system list.
Aug 11, 2014 | Microsoft Xbox 360 Console
What is the default IP of HP ProCurve 2510-48 ?
There is no IP address when the switch ships from the factory. It is set by the user and/or the network by DHCP. If you do not know what the IP address was set to, then you'll need to return the switch ti it's factory default configuration. There should be information in the manual for the switch about the default config.
Jul 02, 2014 | HP ProCurve Computers & Internet
Default password j4868a
The switch ships from the factory with no default username and password. If someone set it and you do not know it then you'll have to reset the switch to it's factory default configuration. There is a reset switch on the back of the unit and when pressed/held in a certain sequence the switch will reset. You'll need to look up the proper procedure in the user's guide of the switch.
Mar 07, 2014 | HP ProCurve 2124 (J4868A#ABA) 24x10/100...
Default password
HP ProCurve Switch 2600 Series Installation and Getting Started Guide
Page 1-9
ftp://ftp.hp.com/pub/networking/software/59908821-0904.pdf
Clear Button
This button is used for these purposes:
Deleting Passwords - When pressed by itself for at least one second, the button deletes any switch console access passwords that you may have configured. Use this feature if you have misplaced the password and need console access.
Jan 03, 2014 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Password user Procurve 2810
If you find the clear button on the front of the switch to the right of the console cable connection. Take a paper clip and press the clear button and then the switch will have no password (unless the front panel buttons have been turned off using the command line commands)
Nov 07, 2013 | HP ProCurve 2810 (J9022A)
Default password for HP procurve j4899a
This link should tell you the answer. http://h30499.www3.hp.com/t5/Switches-Hubs-Modems-Legacy-ITRC/Clear-password-in-Procurve-2650/td-p/4598369#.U0sRNfldUok
Nov 01, 2012 | HP Hewlett Packard J4899B New ProCurve...
J9400b defult ip adress
There should be no default IP address on a 2626 switch. HP Procurve switches are setup by default to get an IP address by DHCP. To execute the factory default reset on the switch, perform these steps:
  1. Using pointed objects, simultaneously press both the Reset and Clear buttons on the front of the switch.
  2. Continue to press the Clear button while releasing the Reset button.
  3. When the Self Test LED begins to blink, release the Clear button. The switch will then complete its self test and begin operating with its configuration restored to the factory default settings.
Be aware, using these instructions will wipe out any configuration you have on the switch
Good Luck
Jan 21, 2012 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
I want reset the factory default of my switch HP Procurve 2510G
Mar 08, 2011 | HP ProCurve Switch 2510G-24 24-Port...
Fault led glowing on hp procurve 2650
operate a factory reset to make sure it is hardware Fault: press reset and clear simultaneously for 3 good seconds then release Clear, when Switch fault and ports start flashing let go of Reset button. If Fault Light still on, contact HP Support.
BE WARNED, this operation will remove passwords and configuration.
Aug 20, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Locked out of HP Procurve 2650 switch
If you have forgotten the switch's IP address or administration password you can return the switch to its factory default state by following these steps:
  1. Remove the power cord from the back of the switch.
  2. Connect port 1 to port 2 on the front panel, using a standard network cable.
  3. Reconnect the power cord to the rear of the switch.
  4. Wait at least 40 seconds before disconnecting port 1 from port 2.
After completing this procedure, the password will be empty, the network address will be returned to the default 192.168.2.10, and all configuration settings will be returned to the original factory defaults. NOTE: Since this process creates a temporary loopback condition on the switch, it is recommended that you remove the switch from a production environment until the process is complete.
Jan 15, 2009 | HP ProCurve 2650 (J4899A#ACC) 48x10/100...
HP ProCurve 224M (J3299A) Networking Switch Logo
260 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
