Question about Kenmore Dryers
The dryer works fine to dry clothes and my question is more inquisitive (and preventive) than a functional problem at this time.
SOURCE: clunking noise
The clunking noise may be a broken weld on the drum. Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise. You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Posted on Jun 11, 2008
SOURCE: Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Posted on Sep 27, 2008
SOURCE: Whirlpool Dryer LGR7646EQ3 - Auto Dry is not working
I went over the part list and I didnt see a sensor, if it is there it will be two silver wire bars either on the back bulk head or at front right just below the door, possibly your timer has gone south too.
The only item I saw was a dryer cycling thermostat that shuts off heat when a certain temp is reached, here is a link;
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=2893&PPStack=1
Posted on Sep 16, 2008
SOURCE: dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Posted on Apr 22, 2009
SOURCE: dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
Posted on May 22, 2009
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
Jul 13, 2011 | Whirlpool Dryers
Feb 25, 2010 | Whirlpool LER4634J Electric Dryer
Jul 15, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Feb 23, 2009 | Dryers
Feb 03, 2009 | Whirlpool LER7646E Dryer
Jan 16, 2009 | Whirlpool GEW9250 Electric Dryer
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
