Question about Mitsubishi LT-52133 52 in. LCD HDTV
I have a 48 inch Mitsu LCD tv that mysteriously changes the volume to the max or min
It is not the remote as i took out the batteries and it still did it
    Top Expert:
  • Mitsubishi Master
  • 75,311 Answers
Electronic volume control section circuit at its main board is faulty. Contact any service technician. This is not a user repairable fault. Your TV need a through check up. Gopakumar Gopalan Google
Posted on May 07, 2014
How do i adjust screen size on a jvc 48 inch tv without remote?
go through menu untill you find screen page and change aspect ratio setting use up and down volume to change it
May 18, 2014 | JVC AV-48WP30 48" Rear Projection...
Volume goes max and will not lower.
Hello
Please remove the batteries from the remote and check whether it is possible to use the local keypad on the TV? If the volume increases, it may be a problem in the local keyboard.
Apr 02, 2014 | Samsung LN32B550 32 in. LCD HDTV
Volume keeps turning itself up philips lcd tv
this is due to surface mount capacitors going faulty on the side buttons panel. You can simply disconnect the cable from this board and use you remote to control the channels and volume. if you want it fixed you will have to replace the side button control panel which is a cheap part.
Jan 29, 2011 | Philips 37PF5521D 37 in. HD-Ready LCD...
I have a Samsung 32 inch LCD tv that constantly changes channel on its own. I switched it on this morning and it was working fine then the volume went to max and I couldn't turn it down. I then switched it...
You say the remote doesn't work but it may well be the problem. Take the batteries out of the controller then try using the tv using the controls on the TV.
Dec 02, 2010 | Televison & Video
My sharp 32" LCD stopped recognizing the remote, b...
I had the same issue with my Sharp Aquos 52 inch LCD TV. I called Sharp. The tech had me unplug my TV, take the batteries out of the remote (TV remote not cable) and press all buttons on the remote (including the buttons under the flip top at the bottom of the remote). I did this, put the batteries back in and plugged in the tv and everything worked. I had gone 4 months having to use the surround sound for volume and turning the TV on and off by hand. This took 2 minutes to fix.
May 20, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
The vizio and the direct tv remote volume is not working correctly, installed new batteries to both. When you push to go up, it goes all the way up and down all the way down. It's like to have a mind of...
i had this problem using dish network. my dish remote went bad so i got a new one and as soon as i programmed it volume and channel had mind of its own on both the dish remote and the original tv remote. you would hit it once and volume would go to max and vice versa when going down. ended up being the new remote was set on the uhf setting and i had to reset to the ir setting which is a small switch in remote next to batteries and then reset system info in dish receiver. problem went away instantly. both remotes work fine now. took two days to figure out and spent hours on internet looking for solution but no one had one. hope this helps.
Feb 03, 2010 | Vizio VF550M 55 in. LCD HDTV
Vizio 42 inch remote is dead. Except volume up /
No,ur main reomte CPU is dead,this problem happen to many remotes in many tv models.Buy a new remote in this website 1-800-Remotes Factory Original.Get the same exact remote.
Jan 13, 2010 | Vizio VW32L 32 in. LCD HDTV
Samsung remote volume control returns to max sound on its own
dear, you have to check your +button whether it is holp the egde of your remote, open your remote and clean, and also check a button on tv for +volume button. there is a pulse condition sensed by the volume control stage. if you can manage do it, or take it to a technician.
Feb 26, 2009 | Samsung Remote Control
JVC AV-48WP30 48 in. Rear... Problem:
Take the batteries out of the remote control. Press every button 2 times. Then re-insert the batteries. While doing this unplug the TV and hold the power button down for 30 seconds. Then let go and leave the TV unplugged for 3 min. Then turn tv on do a channel scan and then try yhe remote.
Jan 08, 2008 | JVC AV-48WP30 48" Rear Projection...
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Mitsubishi LT-52133 52 in. LCD HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
