Question about Building Materials
How do I change the code on my garage door opener?
  • 1 more comment
  • joe one May 14, 2014
    Hi Scott Smith, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Scott Smith
    Scott Smith May 14, 2014
    I have a pyton 2 garage door opener, live in proimityto many others and am experiencing phantom oions. I need to change my code so my door dos'nt open when others activate their remotes.
  • Scott Smith
    > proximity> phantom openings>
  • 71 Answers
SOURCE: opens when we're not at home
Here is the manual, so you can change your code. This should FixYa:) Let me know if you need more help!
http://lib.store.yahoo.net/lib/aaaremotes/976LM-manual.pdf
Thanks!
Posted on Nov 03, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Change the code on a garage door transmitter?
There is a "learn" button on the garage door opener unit itself that you press before entering a code on the outside transmitter. This allows the receiver to learn a new code. The button is on the rear end of the housing near the terminals where the inside operation pushbutton connects.
Here's a link to programming instructions for a compatible unit by another manufacturer:
http://www.usdoorcontrol.com/instructions/liftmaster/keypads-66LM.pdf
Posted on Nov 23, 2008
SpotBert
  • 231 Answers
SOURCE: Door opener remotes not opening garage door.
You have to sync the remotes to the new code. For older remotes, you can open the remote and match the pin settings.
For newer remotes there's a button that you push in the back of the opener that sets in program mode (for Chamberlain). When you push the remote button, it will acknowledge the remote is programmed.
If this doesn't help, comment back on your particular model and we'll help you with the solution.
Posted on Jan 03, 2009
  • 3197 Answers
SOURCE: I have LiftMaster garage door model 41A3039 and
To program the keypad, first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Posted on Jul 13, 2009
  • 3197 Answers
SOURCE: Trying to clear the codes from my Garage Door
In most cases, when a garage door opens or closes by itself, or when you find your door open, upon returning home, the problem is due to a short somewhere. This short is most likely to be in one of two places: either in one of your transmitters or in the wall button or its wiring.
When there is a short in your garage door transmitter, you will often find the garage door is up upon returning home, even though you know you closed the door when you left the house. A short in your transmitter causes a continues signal to be sent. As you are pulling out of the driveway the garage door closes fully and appears to stop, but as the carriage and arm run past the down limit and hits the header bracket it reverses, and the door begins to open, just as you start driving off down the road. You come home to find the garage door is up, as if someone else had opened your door. The best thing to do to troubleshoot the garage door problem is remove the batteries from your transmitters and try operating the door from the wall button. If the problem is intermittent, you may want to do this for a day or two to eliminate the transmitters as the culprit.
If the problem persists, try removing the wall button wire at the motor head to ensure it is not a short in the wire to the button, then try operating the garage door with the transmitters only. If it stops the problem, replace the wires and test the wall button. It is a process of elimination.
Posted on Mar 29, 2010
How do I change the code on my garage door opener. Have one and lost one.
Press an hold the learn button on the garage door opener for 10 seconds. You will notice an amber LED either next to or above the learn button. When the LED goes out the anything that was previously programed will be deleted. Now press and release the learn button once the amber LED will come on steady. Now press the button on the garage door opener you want to program to the garage door opener. You will hear a click and the light bulb on the garage door opener will go off and come back on. Your garage door opener remote is now programed with a new code.
Feb 22, 2015 | Chamberlain Televison & Video
How do I change the code on my Genie garage door opener
The opener stays the same but the garage door opener learns the code the opener sends. My newest one has a code button on the garage door opener and I press the opener button and the light flashes and it is paired.
Dec 11, 2014 | Building Materials
Garage doors opens on its own, after being close for hours
Someone in your neighborhood may have the same garage door opener that you have and sharing the same code. Change your garage door opener code or buy a Genie Code Scrambler.
Apr 05, 2014 | Genie Garage Door. SilentMax 1000 3/4 HP...
I changed the code on my Craftsman garage door opener and I don't remember what it is. Now I can change it to a new code. The door will not open How do I reset it?
To change the code press and immediately release the smart/learn button and walk over to your keypad and key in any 4 digit code and press enter.
May 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have liftmasterPro garage door opener. How do i
You cannot change the code of the opener without purchasing new remotes and not using your existing remotes. To change the code of the keypad locate the smart/learn button just to the left of all those white wires. Press and immediately release this and then walk over and key in any 4 digit number and press enter.
Sep 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Changeing code for garage door opener
If you want to change the keyless entry code just press the green learn button on the motor, Enter a four digit code and press the enter button within 30 seconds.
Mar 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
