Question about Zanussi ZBF360X Electric Single Oven
Zanussi oven keeps cutting out - Zanussi ZBF360X Electric Single Oven
  • Zanussi Master
  • 5,323 Answers
The reason for my free advice is GOD is good!
Oven comes on and off intermittently or heats very little:
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
Posted on Apr 29, 2015
2 Suggested Answers
  • 417 Answers
SOURCE: zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Posted on Dec 26, 2009
Glass door for top oven
Really bad but how we are supposed to help you? Find a shop where they sell parts for Zanussi ovens.
Most I can do for you is to provide you some websites selling parts for zanussi: ovens
Official Zanussi Site Parts Accessories for Appliances
Zanussi Cooker Oven Shop
Find Zanussi Spares and Accessories
Zanussi Cooker Oven Spares
Oct 25, 2015 | Zanussi ZDQ695 Electric Double Oven
Zanussi error 10
maybe check oven element also the controller
Nov 13, 2013 | Ovens
Oven won't turn on, had a power outage on the street 3 times today. Tried flipping the fuse, but nothing has happened. Any suggestions? Not sure which model Zanussi it is, except it is not brand new!!
The electronic clock/timer must be in manual mode for the oven to operate. When the power to the oven is cut the electronic clock/timer reverts to automatic mode when the power comes back on.
Mar 07, 2011 | Zanussi ZBS963X Electric Single Oven
Zanucci Electrical fault. Oven cuts out and fO8
Is the model number correct. ZBF360X.
Anyway the error code fo8 normally relates to a faulty Tangential Fan.(Cooling Fan),which can be found on teh top of the cooker behind the control panel and it is there to cool said panel.
Hope this helps.
May 24, 2010 | Zanussi ZBF360X Electric Single Oven
Zanussi zbf260x built-in oven keeps tripping out
Dec 26, 2009 | Zanussi ZBF260 Electric Single Oven
Zanussi 360 just tripped and now keeps tripping
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Please rate my solution.
Thanks.
Nov 11, 2009 | Zanussi ZBF360 Electric Single Oven
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
Why does my oven keep switching off?
there is a casing stat which senses overheat. this can be due to lack of ventilation if a built-in type or a fault with the fan
Jan 27, 2007 | Zanussi ZDQ895 Electric Double Oven
Zanussi ZBF360X Electric Single Oven Logo
151 people viewed this question
Top Zanussi Ovens Experts
ashburton
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
