Question about Sharp Aquos LC-M3700 37 in. HDTV-Ready LCD Television
When i push volume
Thes tv asking for code and don't have it
    Habit-Forming:
  • 166 Answers
Without more information, it sounds like someone might have set the parent protection code. Was your TV a demo unit maybe? You should be able to reset to factory default settings, but you'll need the manual for the TV for this. If you have more details on when and where you see this message, please elaborate.
Posted on May 08, 2014
My remote won't change from AUX to Tv and all of the buttons don't work on AUX except for the volume and mute, how do I get it back on tv? Thank you
Try to push the TV button that is lit red at top middle of remote for 5 seconds in stead of hitting input. In other words by holding the tv button down it might trigger it to respond better. Thanks Mike
Apr 07, 2013 | Televison & Video
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
Un do you unlock a harmontec tv/dvd 210
hi welcome to fixya
if you don't mind sir just for clarification are you asking for unlock code for harmon tec dvd player model 210?.just give feed back if it is what you are asking for so i can give you additional solution.
Aug 24, 2011 | Televison & Video
Need code to use for the tivo remote
Push the TiVo button on the remote. Then push "Messages and Settings," followed by "Settings," and finally press "Remote Control." This will show you the three areas of the remote that are programmable. "TV Power, Volume and Mute," is one section. "AV Volume and Mute," is the second section. The final section is "TV Input."
Pick "TV Power, Volume, and Mute" by pushing right on the direction pad of the remote. This will open up a list of all the brand names of TV that exist. You will find most TV brands will be there.
Find your brand of television and select that option. If your brand is not there, simply go to the TiVo webpage and under "Setup and Support" you will find others who have experience this issue. There you will find a code for your TV. This happens sometimes when the TV is a lesser known brand.
Hold down the button you are programming (i.e. TV Power) for 5 seconds until the red light on top stays on. Then enter one of the codes on the screen.
Push the newly programmable button to test its functionality. If it does not work, repeat the steps with all the possible codes available. One of the codes will work.
Push "Live TV" at this point to watch television.
Use the manual which came with your TiVo in addition to this guide. In the front of the booklet will be a starter guide, which will lead you through the steps necessary to set up your remote for optimum use.
Mar 23, 2011 | Televison & Video
I have a philips universal remote and I need to program it to a Sanyo T.V.
is easy to program if you don`t have the # code turn on you tv and just hold the the code seach or set up button until the red ligth stay on and then selec what do you want to program tv,vcr,etc push and let it go then push power until you tv turn off then push enter to safe the code if you push one more time after turn off you tv you have to star over
Apr 12, 2010 | Sanyo DS31520 31" TV
Direct TV remote does not control TV on/off or volume.
I have some codes hope they will help. slid remote to tv and hold away from tv as u push mute and select till light blinks twice. then point at tv and try these. 10154-10236-10463-10178-10171-101179 good luck
Sep 25, 2008 | Emerson EWF2704 TV
Volume controls dont work when using remote
I would start by trying other codes on the universal remote. Sometimes codes will only work part of the remote such as the numbers or channels but not volume. Your motorola cable remote sounds like it may only need a good cleaning. sometimes when you take remotes apart it will look like somthing got spilt in it. I would start there first.
Mar 17, 2008 | Sanyo DS27910 27" TV
Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Making my SIR-T451 remote work with my Zenith TV.
Push the Set button and enter the following codes and enter one of theese codes: 018, 020, 193. If one doesn't work try the next one. You have to push set each time you enter a new code.
Jan 11, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
Sharp Aquos LC-M3700 37 in. HDTV-Ready LCD Television Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
