Question about Home
HOW TO REMOVE FIREPLACE FROM THE WALL MOUNT MODEL #MH35BL
SkinWill
  • 148 Answers
SOURCE: wall mount for 52in tv ?
Here is a mount rated for your size TV http://www.bhphotovideo.com/c/product/518312-REG/Bentley_PLAW_6000FB_PLAW_6000FB_32_60_Flat_Panel.html
Also, be VERY careful mounting ANY plasma above a fireplace. Plasma sets are typically convection cooled to avoid the noise of fans. The heat from a fireplace will GREATLY reduce the life of the set. When people I know insist on putting a set above a fireplace I usually insist they install a cooling fan with ducting that will vent fresh air to the set. If you are concerned about the temp of your set simply consult the owners manual for operating temperature and measure the air above the fireplace yourself. BHphotovideo.com typically has good prices on mounts along with amazon. most other places like bestbuy or circuitcity will stick you on the price of the mount because they make their money from accessories. Also, why did your last set die? plasmas are typically rateed for 10+ years, did yours over heat and start to change colors?
Posted on May 17, 2008
shaggyrat
  • 1224 Answers
SOURCE: remove tv from wall mount
there is an anti theft device on the wall mounts you need the manual to adjust mount to take off
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=255670bad135aec3653b726b698def9d&q=Samsung+PDP4294
heres the link just follow instructions to get download i will also be posting it here on fixya too
this the manual
Posted on May 26, 2008
SOURCE: Remove the base for wall mount
just spoke with a Coby technician. Where the base connects to the TV you can literally just squeeze in those the plastic pieces and they come right off. After that just unscrew the screws underneath. Just did it and it was very easy.
Posted on Dec 18, 2009
  • 382 Answers
SOURCE: WILL BE BUYING LCD TV IN NEAR FUTURE, BUT NEED TO
Absolutly, I have wall mounted a few dozen above fireplaces in the past 5 years; I can even send you over some pictures and suggestions come time for the install.
What is the wall material? Brick mantel or drywall with wood studs?
Although a TV looks attractive about a fireplace you have to consider that it is fatiguing to watch from such a high height. The optimal average height for a TV is 45" to centre (depending on furniture). If you exceed that by a few feet watching a lot of TV is awkward.
The advantage is it combines the focal point of the room, and instead of having a picture about a fire place, your TV becomes the work of art and can be used as a digital picture frame.
Posted on Jan 01, 2010
  • 1779 Answers
SOURCE: I need an original mounting base that will fit a
Your stand is in stock at www.shopjimmy.com part # sj-1701-0529-3010......$41.97
Posted on Nov 27, 2010
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
What thermostat will work for my gas fireplace?modelwh060396b 07/2006 has remote want a wall mount
A search for that model number did not yield any results. A brand name would help.
That said, if your gas fireplace has a milivolt valve with "TH" and "TP/TH" terminals on the side (for hooking up a remote, thermostat, or switch), then you can use a universal wireless wall system.
You can find wireless wall systems for gas fireplaces HERE.
Dec 23, 2012 | Heating & Cooling
I just bought a 46 inch SAMSUNG LED HD TV from Best Buy and will be mounting it on a brick wall above the fireplace. The fireplace has gas logs with a an 8 inch mantle that extends 8 inches off the...
it is not safe to mount the TV 8 inches above the mantle.
Secondly, the heat will certainly be a danger if the TV is mounted above the mantle.
I would advice you look for another position to mount the TV.
I hope the above is clear.
Regards.
Sep 27, 2011 | Televison & Video
Where does the FBK200 blower go in the Marco fireplace
As you are aware the Marco Fireplace Co is no longer in business. However, the blower model # you listed is a DESA/Vanguard part number. In any event, it may work.
The blower goes in the lower compartment (probably louvered) under the firebox. It is then attached to the rear wall of the compartment, with the blower output facing up the back wall of the firebox. There should be an arrow on the blower housing indicating which way it should point.
If your firebox is already wired for a blower and has a duplex receptacle in place (for the blower to plug into), you're in business. If it doesn't I highly recommend that you install one and not try to hard wire the blower.
The blower, if purchased new, should come will all the hardware to mount it. If it didn't you can use sheet metal screws to attach it to the rear wall of the firebox. However, make sure that you put a rubber flat washer behind the mounting frame and then screw thru it into the firebox wall. This will help eliminate vibration and noise.
Hope this helps to get you started.
Feb 25, 2011 | Heating & Cooling
Right after they were apprx one yr old they started clicking
The metal chimney is expanding and contracting ... turn up the mood music or start the fire sooner so it will be hot when you are ready to enjoy the atmosphere.
May 10, 2010 | Dimplex Copper Wall Mount Electric...
How do I wall mount the 65" TV. There are no instructions in the manual provided with the TV
You can buy a universal wall mount the will fit on that 65" plasma that comes with all necesary hardware and instructions to mount the TV to the wall. Now that 65" tv is really heavy so it needs good anchors to support the weight of the display.
Jan 02, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I have a Town & Country fire place with a MAESTRO Control System which includes a wall control and hand held remote. There is a red light flashing on the bottom of the wall control under what appears...
Hi
behind the wall control there are 4 AA batteries that need to be replaced. you have to remove the wall control plate with a screwdriver and the batteries are tucked into the wall behind the wall switch.
ps - my husband is an electrician and he wired the fireplace but forgot that there were batteries behind there! it was me who asked for the screwdriver. ha!!
Dec 25, 2009 | Grilling
Wall mount for 52in tv ?
May 17, 2008 | Televison & Video
Just a consumer quesstion.
Heat rises and smoke has particulate matter in it. And heat is the enemy of electronics. So personally, I would not mount any expensive TV over a fireplace. However, if you have nice glass doors covering your fireplace opening, good updraft in your fireplace, and a large mantel that projects out over the opening, you will probably get reasonable life out of your LCD TV.
Sep 11, 2007 | Televison & Video
Home Logo
43 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
