Question about GE Washing Machines
What size bearings for wmd960g
I need size for bearings and spider for this washer cause there is 30mm and 35mm bearing kits dont know which i need
early1234
  • 871 Answers
SOURCE: Replace bearing on washing machine
this may help you out.
Replacing Drive Belts and Tightening Pulleys
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
Servicing the Motor
In most cases, motor malfunctions should be handled by a professional; do not try to fix the motor yourself. If the motor is a universal motor, however, you can change worn carbon brushes when sparking occurs. To save the expense of a service call, remove the motor from the washer and take it to a professional service person, then reinstall the repaired or new motor yourself. To access the motor, remove the back panel of the washer. The motor is mounted on an adjustable bracket.
There is one other motor problem you can repair yourself. Washer motors usually have an overload protector clipped to the motor. When this component fails, the motor won't work. Before you take the motor in for service, test the protector with a VOM set to the RX1 scale. Disconnect one electrical lead wire to the protector and clip one probe of the VOM to each protector terminal. The meter should read zero. If the needle jumps higher, the protector is faulty and should be replaced. Pry up the protector with a screwdriver and replace it with a new one made specifically for the motor or washer. Connect the new protector the same way the old one was connected.
Servicing a washing machine can be a frustrating home repair project. Because a washer has so many different cycles and functions it's not always apparent what exactly is going wrong. With the troubleshooting tips in this article, you should be cranking out loads of clean laundry in no time.
Posted on Mar 21, 2008
duby1990
  • 370 Answers
SOURCE: Maytag bearing issue
Get the kit.
Posted on Nov 18, 2008
  • 61 Answers
SOURCE: Replacing maytag thrust bearing kit 12002213
yes you can do it yourself no special tools are need just a couple good flathead screwdrivers and a lot of patiance be sure to put all the new washers and bearing back on in the same order the old ones came off putting the C clip on can be a little tricky but take you time and it can be done you may hvw to use the flat head to pry on the trans. shaft to get the clip in the groove then use a pair of chanell locks or pliers to snap it on if you get a new style bearing it may not look like the one you take off and not have all he washers just snap the small plastic pice onto the bearing put it on the the pulley the most of the time just the thin washe then the C clip the dust cover put belt back on the test machine
Posted on Jan 20, 2009
scottowa
  • 87 Answers
SOURCE: Are the bearings easy to change on hotpoint WMA42p
I'm sorry to inform you but if it's a bearing, the machine is ready to be replaced. Those usually take 2 people about 1 /12 to do. The bearing is not a separate item. You need to replace the back basket and then the drum assembly since that is the shaft that gets scorn. Usually this always happen to machines that people do not use HE soap in or use too much soap. This is way too common and usually cost about $600 in parts only. I wish there was a better way but un-less it's under warranty, we never usually fix them becuase it's chepaer for a new machine. Sorry for the bad news my friend
Posted on Mar 22, 2009
apart4u
  • 213 Answers
SOURCE: Hotpoint WMA54 - in middle of attempting to
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Posted on May 27, 2010
How to change ball bearing washer machine
Washing machine main bearings are not a picnic to replace and often needs a major stripdown for access.
If the washer is otherwise in good condition and a premium brand it is an economic repair for the repair shop to carry out. Great savings can be made by changing the bearing yourself but do not begin the job unless you are certain you are competent, have a good range of tools to hand and prepared to spend more once the job has begun. As well as the bearing kit you will need a new tub seal and possibly a new spider.
It is generally reckoned not to be economic to have the bearings replaced at the repair shop if the machine is a basic or budget model. In this case it is definitely a diy project.
Oct 06, 2015 | Washing Machines
Hi Which steering head bearing kit do I go for?
the best way is to measure with a vernia caliper the inside and outside diameter of the top and bottom bearings you already have and compare them with what you were going to buy. for instance the bottom bearing may have a 30mm OD and a 45 mm OD and be 13 mm high.i strongly recommend you fit taper roller bearings to it .
Feb 20, 2015 | 1977 Suzuki GS 750
Lescha Hobby 125 S electric mixer requires new drum main bearing
I had a similar problem on a Lescha Hobby Mix 120 SF. (Sounds similar to yours) The failure seems to have been caused by corrosion of the ball bearings. If you get water into the rear bearing housing when it is operating, and then store the mixer with the opening in the drum downwards, the water collects around one of the bearings. The bearings are a standard size ball bearing with a 62mm outside dia, 30mm bore and 16mm wide. I bought the sealed version from a local bearing supplier (or look one up on the Internet). The original ones fitted are unsealed, which is part of the problem. I also bought two new bearing retaining external circlips for a 30mm shaft. I had a paint round inside the housing with hammerite, and drilled some 10mm dia drain holes around the outside of the housing near the bolting flange. I also store the mixer with the drum horizontal now.
May 27, 2011 | Gazillion Cement Mixer
It makes loud noice when spining or by hand it flops to one side?
Noise when spinning, seems to be the bearing are worn out or broken. The washing machine needs to be opened while disconnected from the a.c. mains. It may be necessary to lift the drum out of the machine to get to this, if direct access from the rear is not available or awkward to get tools in.
At the rear of the drum there is a wheel connected to a belt. Beneath this wheel are some spokes (called a spider) which is bolted to the drum. This spider needs to be removed and the center bearing hammered or pulled out using a bearing puller (automotive garages use them) without damaging the spider. The bearing will have a rubber seal on top which can be removed with a screwdriver. Normally the seal and bearing is replaced as part of a kit. These are available on ebay, contact the seller with model number GHW9150P to make sure, see example search below.
http://www.ebay.co.uk/sch/i.html?_nkw=whirlpool+bearing&_sacat=0&_odkw=GHW9150P+bearing&_osacat=0&_trksid=p3286.c0.m270.l1313
When Replacing the bearing and add grease so that it is well lubricated.
Reassemble in reverse order
Mar 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
So my Dynacraft Next turbo bicycle crank arms and pedals were wobbling and found out the issue was a bent bearing.So instead of taking it apart,we decided to hammer the bent bearing back into the crank...
the little balls are the bearings, ie: ball bearings, so they are the size, take them to a bike shop and get a replacement kit.
Your crank is probably not bent , it takes a big crash or something to bend one. there is an adusjment nut and lock nut to set them back up. could be LH thread on the left hand side
Feb 12, 2011 | Dynacraft Next Turbo Children BMX Bike
Bad bearing
if the bearings are rusted or seized u need to change main seal near bearings. was it noisy b4 you looked at bearings?could be broken spider that holds bowl.please reply if u need more help
Mar 31, 2010 | LG WM1814CW Front Load Washer
Hotpoint WMA54 - in middle of attempting to replace the drum bearings. I've split the drum apart and am attempting to remove the existing bearings and spider; however, I'm unable to separate/unscrew the...
Jan 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Are the bearings easy to change on hotpoint WMA42p washing machine, and are they the 35mm or 30mm bearings as some sites seem to vary
Mar 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA35 - Noisy on spinning
This could be the bearings.
If it is you have two options:
1 - Buy another washing machine
2 - DIY possible for about £30 with all the RIGHT TOOLS, £100 if doing it properly. And even with the right tools this will take you about 3 hours, probably more.
To replace the bearings you NEED to have:
1) The parts - The replacement bearing kit (£30) and hotpoint recommend a new spider (£65) as well.
2) A tool to push the drum shaft from the casing.
3) A tool to remove the beaings. It is possible to buy a new rear casing with the bearings already fitted for about £70.
4) Patience and a supply of tea!
Method
1 - disconnect everything and I mean everything see number 2.
2 - remove the drum casing from the chasis
3 - take off the pulley wheel
4 - open the casing
5 - remove the drum from the casing. DO NOT USE A HAMMER as the shaft deforms very easily (good job I've a new "spider"!)
6 - fit new "spider" if using. Here is where you find the bolts are rusted completely solid from spider to drum and require drilling out.
7 - remove bearings from casing (hence the need for the bearing removal tool)
8 - fit new bearings and rebuild machine (hence the need for the bearing fitting tool)
However I stopped at number 7 due to not having the right tools and I have no idea how much the right tools cost.
Trust me, take option one! £100 is a third of a new machine!
Mar 17, 2009 | Hotpoint WMA35 Front Load Washer
Change Bearings for HotPoint WMA62N
Hi, I also have the bearing problem on a hotpoint wma and have just stated the repair job. I have found the following on different forums, so maybe it might help others. You do need to remove the drum and there are two different sizes of bearings 30mm and 35mm. To find the size you need you have to get to the bearings and measure them.
. Ok,Hotpoint wma series drum bearing failure.Firstly very common problem since i work on these things every day-i think there is a design fault-nothing new in this trade!What follows is
the sequence of problems in changing the drum bearings:If the machine has been thrashed into oblivion just changing the oilseal/bearings will have you back to square one within a
couple of months since you would`ve damaged the drum shaft as the bigger bearing of the 2 goes into shapnell mode!So you`d best change the drum shaft(in the trade known as the
spider) however this thing is aluminium usually held onto the the drum via torx headed screws either in steel or soft Al2 also-forget it as your not going to get these out unless your mega
lucky,what we do at work is to replace the whole tank/drum/bearing assembly which comes with a new element and belt ie the whole tank unit,the trade price of this part is less than
£100.00-you can draw your own conclusions as to the retail price as you wish.If you haven`t thrashed the machine you can get away with replacing just the bearings or easier still the rear
half of the tank(trade price 30.00+vat) in which the bearings are already fitted via the factory and reuse the existing spider/drum shaft so long as it isn`t damaged by disintergrated bearing
shapnell.I hope this clears up this problem for you.Please note that this machine`s filter which is at the rear doubles up as the air trap-the oval section 8" long semi transpatent plastic tube
thing-the part that allows the water to compress the air so turning off the level of fill at the right level via the round swt behind the soap dispenser-called the pressure swt-if the filter gets
bunged up the machine o/fills and either overfills or overfills and floods or tries to spin with aload of water still inside the drum or perhaps no spin at all.Hope this helps someone.
The drum comes out through the front on this one. Take off kick plate and remove screws holding front panel to frame. Take out soap drawer & remove screws behind it. Take off band
holding door seal & peel seal back. Remove 2 screws holding door lock &push lock through. Pull control panel forward at left side & slide to right to remove being careful with board &
wiring. Remove screws holding top end of front then lift slightly &remove front. Remove back panel & take wiring off heating element & pump. Disconnect the pump hose at the drum end,
disconnect the hose from the soap dispenser, note that wiring is fastened to the drum at several points and will need to be disconnected. Remove panel from behind control board then
carefully move everything away from the front of the machine, the drum can now be lifted clear.
Forgot to mention unplugging motor but common sense will prevail.
Mar 11, 2009 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
