Question about Miele W526 Front Load Washer
How do I change the seal on a Miele W526 washing machine?
I have removed the top and soap dispenser. Can't see a way of removing the front display. Please help. My wife can't wash my clothes until it's fixed!
    Habit-Forming:
    New Friend:
  • 86 Answers
Dont remove eather!
Only the front!
Remove seal front ring on the front. Its one 10mm bolt under the seal on the front, undo this, and the two srews on the door lock. And two srews on both sides under the front. The the whole front is now loose and can be removed.
Then take of the inner seal ring, and unplugg drum ligths/hoses if any.
Replace seal....
Posted on Jun 19, 2014
  • 16 Answers
SOURCE: miele novo w526
Can you hear the drain pump running??....If so the WPS system has been activated and there is water in the base.
If not, please post back if any water is going into the main wash compartment once it's started. No water, then faulty inlet valve.
Posted on Feb 08, 2008
Master_Tech
  • 770 Answers
SOURCE: Miele leak when switched on for wash, from filter unit front LHS bottom of machince
You can replace the Bellows as it is called but to fix it before you replace it clean it with Bleach to kill the mold and then dry it ALSO after any load you do leave the door open a bit this allows the mach to air dry out and prevents the build up of mold ..Good Luck plz rate this post for me
Posted on Feb 17, 2008
SOURCE: Miele W 1918 washing machine front door seal replacement
the seal on the front door runs around 60 bucks and its quiet easy replaced takes 1/2 hour
Posted on Jun 06, 2008
  • 177 Answers
SOURCE: How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Posted on Jan 18, 2010
Testimonial: "Thanx for the help. I managed to get my first wash very successfully. "
  • 70 Answers
SOURCE: My Miele Novotronic W 844 Washing Machine will not
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent from drain pump blocked.(Vent left front side of soap drawer. Visible when drawer removed)
Posted on Mar 30, 2010
Remove control panel from Miele W3240 washing machine
Go to www.repairclinic.com and enter W3240. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Miele video showing disassembly.
Sep 30, 2017 | Miele Washing Machines
Cannot remove dispenser draweer on Kenmore model#417-44042400
it may have been jammed when shutting to hard try seeing if any of the plastic as bent inward and needs to be bent outwards so u can remove it :D..... also can u please answer my question :D
Jul 02, 2012 | Miele W526 Front Load Washer
Replace bellow seal
Hello.
1 Unplug the power cord. Pull the Whirlpool Duet away from the wall. Remove the screws at the back of the machine using a Phillips screwdriver. Remove the top panel from the machine and set it aside.
2 Remove the soap dispenser from the front of the machine by pulling it out and depressing the button at the back to release it. Remove the soap dispenser bracket retaining screws, using a Phillips screwdriver. Pull the dispenser bracket out of the washer.
3 Remove the retaining screws from the control panel with a Phillips screwdriver. Release the locking clips and flip the control panel on top of the machine. There is no need to disconnect the wiring harness. Open the washing machine door and remove the retaining screws from the door latch, using a nut driver.
4 Remove the outer retaining spring from the bellow seal using a pair of needle-nose pliers to grasp the loop and pull it out. Peel the bellow away from the door opening, using your fingers. Push the bellow seal inside the machine after you release it from the door opening.
5 Lift the front of the washing machine and put a wooden block under it.
Remove the retaining screws from the bottom of the front panel using a nut driver. Remove the wooden block from under the washing machine and lower the unit back to the floor. Remove the screws at the top of the front panel with a nut driver. Pull the panel away from the machine and set it aside.
6 Pull the old bellow seal from the machine. Unplug the white and black hoses from the old bellow seal . Remove the spring clamp from the bellow and throw the old bellow seal away. Rub liquid laundry soap on the groove of the new bellow seal. Push the new bellow seal onto the washtub with the opening for the hoses at the top. Push firmly until it is on tight.
7 Install the spring clamp on the new bellow seal into the groove using a Phillips screwdriver. Plug the black and white hoses into the holes at the top of the bellow. Be careful not to damage the bellow seal. Place the front of the machine on the frame and install the top screws using a nut driver. Push the door latch through the hole and install the retaining screws.
8 Press the bellow seal into place around the door opening and install the spring clamp around the perimeter of the bellow. Lift the machine and place the wood block under it. Install the bottom screws with the nut driver. Remove the wooden block and place the machine back on the floor. Put the control panel in place and lock the retaining clips.
9 Install the soap dispenser bracket and the retaining screws using a Phillips screwdriver. Install the retaining screws on the control panel. Place the top cover on the machine and install the screws with the Phillips screwdriver. Plug in the power cord and push the machine against the wall. Install the soap dispenser drawer and push it all the way in so the tab locks into place.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How to remove front panel on miele w524 washing machine to replaer elementce heat
very simple ,first thing first always unplug washing machine from main socket, remove top cover reomove soap drawvremove three screw from inside soap draw, remove kick pannel at bottom to reveal drain pump ,remove door seal held by spring ,remove two scrw where door strikre goes in ,then you should beable to lift of whole front which will reval heating element
Oct 18, 2011 | Miele Novotronic Premier 500 Front Load...
HOW DO I CHANGE THE DOOR SEAL ON MY WASHING MACHINE, HOTPOINT WMF540PUKR
The front panel comes off 3 screws top and 3 bottom, you will need to remove soap dispenser and front Facia first,once you remove front undo the door interlock 2 screws and let it hang by wiring,this will expose the door seal you will need to undo the seal from front case to remove it then the inner ring at inner drum,now easy to get at......you could look at utube video how to or website Espares.co.uk they explain very well..Good luck
Jul 04, 2011 | Washing Machines
How to change miele novotronic W828 door seal?
Turn the machine off and unplug it! There are 3 10mm bolts around the door that need to be removed, the soap dispensing drawer needs to be taken out and you have 3 torx20 screws (one on the left and 2 on the right) that have to be removed. The bottom left corner of the machine there is a small door that you open, remove the hose that's clipped inside it, there is a small tab on the lower left, release the tab, pull open the door. To take out the seal you have to loosen the 8mm bolt band clamp, and pull the seal off. Fit the new seal on until you hear it pop. and reverse the order.
Hope it works for you.
Feb 28, 2011 | Miele W526 Front Load Washer
The soap dispenser door will not open. How do I remove the top of the washer to access the soap dispenser? I know that the blue plastic piece for the fabric softener lifts up when I try to pull open the...
To remove top: Remove the bottom screw from the plastic clips on back of the washers top. next, stand in front of machine and, using the palms of your hands, sharply push the top back about 2 inches, allowin you to lift the top off.
Dispenser issue: you may have to drill a small hole in the plastic top of the dispenser to allow you to push the offending part down while pulling on the drawer. seal the hole with silicone or foil tape.
Feb 20, 2011 | LG WM-2277HW Front Load Washer
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Solution for washing machine
  1. remove top cover.
  2. Remove soap dispenser draw.
  3. unscrew the screws securing the the soap dispenser to front console.
  4. Pull timer dial off, noting position of symbols.
  5. slide console panel to right, and lift up out of way of front panel.
  6. Undo 3 screws securing top of front panel.
  7. undo 2 screws securing door interlock to front of panel.
  8. Remove plastic clip securing door seal to front of panel.
  9. remove wire clamp band round front of door seal.
  10. Undo 3 screws at bottom of front panel securing it to cabinet .
  11. remove front panel.
  12. Unscrew thye top wire clamp band securing the seal to drum front.
  13. remove door seal.
  14. Fit new door seal, making sure the drainage holes are at the bottom dead center.
  15. reassemble in reverse order.
  16. Please rate my solution.
  17. Thanks.
Nov 06, 2009 | Washing Machines
Miele W526 Front Load Washer Logo
172 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
