Question about Bosch Washing Machines
A key appears on the screen and prevents the dryer from operating. How can I resolve this?
How do I remove the key on the screen?
My pc laptop does not start due to error 2000-03000
Try using the Last Known Good Configuration:
  • Remove any CD or DVD from your computer, power down, then power up.
  • Do one of the following:
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start, and then press F8.
  • On the Advanced Boot Options screen, use the arrow keys to highlight Last Known Good Configuration (advanced), and then press Enter.
  • If your computer has more than one operating system installed, use the arrow keys to highlight the operating system that you want to start by using Last Known Good Configuration, and then press Enter. Windows will then resume starting normally
  • Nov 13, 2013 | Dell Computers & Internet
    No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
    Instructions
    1. Dryer Does Not Run
      • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
      • 2 Press the "Start" button firmly or push the knob in to start the dryer.
      • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
      Long Drying Times
      • 4 Remove the lint screen. Clean it and replace it.
      • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
      • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
      • 7 Separate large loads and do not use an air dry cycle.
      Lint, Stains and Wrinkles
      • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
      • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
      • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
      Dryer is Noisy
      • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
      • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
      • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
    Jan 15, 2013 | Admiral Dryers
    DSR_40P.when rew or fwd is near end,c-32 appears
    The unit is equipped with the self-diagnosis function that works to prevent the VCR from malfunctioning. A two digit service number appears in the display window. In this case, check the following.
    Number 32
    To prevent the unit from malfunctioning, the self-diagnosis function has worked.
    Remedy • Disconnect the power cord. After reconnect it, operate the unit. • Remove the cassette or turn on/off the unit.
    Number 21
    Moisture condensation has occurred.
    Remedy • Remove the cassette and leave the unit for at least one hour.
    If you are unable to resolve the problem, contact your Sony dealer or local authorized Sony service facility and inform them of the number.
    Dec 01, 2009 | Sony DSR-40P VCR
    Condensation please wait constantly appears on the screen unable to do anything the camera seems to shut itself down it wont even let me load a tape in.it wont record playback nothing.
    There is a "dew" sensor inside that is preventing the unit from accepting the tape. This is a safety feature to prevent damage to the tape. If there is any moisture inside, the tape will stick to the heads and get damaged. Open up the unit (eject) and point a hair dryer toward the opening with the dryer about 12" away. Let the warm air flow for 10 minutes or so and try the camera again. If that failes to resolve the problem, then either the sensor is defective or the connections to it are defective and the camera should see a servicer for repair.
    Good luck,
    Dan
    Nov 05, 2009 | JVC GR-D70EK Mini DV Digital Camcorder
    All i get is the welcome screen and no light by the standby button. it has power
    If normal operation has the welcome screen dissapear after a few seconds followed by working properly, it appears the internal software is corrupt or buggy.  Try a power drain:
    1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
    Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
    If this doesn't resolve it, the Toshiba will require service for defective software.
    Mar 26, 2009 | Toshiba SD-H400
    Bosch Classixx 6 1200 express front load washer - the 'screen' has a lock symbol on it, preventing operation: not sure whta this means or how to resolve, please.
    The 'start' button appears to contain a lock - possibly a child lock. Hold the button in for a few seconds to clear the lock
    Mar 25, 2009 | Bosch Washing Machines
    When operating, dryer makes sound like metallic rubbing
    IF LINT SCREEN ON TOP REMOVE 2 SCREWS, THEN SLIDE (pull) TOP TOWARDS U NOW,, DISCONNECT POWER FIRST,EACH SIDE HAS 2 5/16 SCREWS REMOVE ,UNPLUG DOOR SWITCH , PULL FRONT PANEL UP TOWARDS U NOW YOU CAN ACCESS WHOLE DRYER ,,REPL/ ROLLERS.IDLER PULLY SHOULD RESOLVE PROBLEM
    Jan 02, 2009 | Kenmore 62622 Electric Dryer
    Hp dx2000 boot problem
    Hi Robert,
    please try these troubleshooting steps,
    Resolving the blank screen Follow the instructions below in order to fix this issue:
    1. Remove any CDs, DVDs or memory cards from the computer.
    2. Disconnect all devices from the computer leaving only the original mouse, monitor and keyboard and power cord connected.
    3. Restart the PC. NOTE: If this resolved the issue, see the Preventing the blank screen section at the end of this document.
    4. Press the F1 key repeatedly during the first startup screen until the entering setup message appears.
    5. Press the F5 key to restore the default settings. Use the arrow keys to select YES and press ENTER .
    6. Press the F10 key to save the changes and exit. Use the arrow keys to select YES and press ENTER . The PC restarts.
    7. When the system restarts select Last Known Configuration from the boot menu. The PC should now startup normally. If the blank screen persists continue with the following steps.
    8. Select Safe Mode from the Windows Advanced Options Menu .
    9. Use Microsoft's System Restore feature to restore your computer to an earlier time and correct the issue.
    Jun 23, 2008 | Computers & Internet
    Dell desktop
    3. Restart the PC.
    10. If disconnecting devices from the PC resolved the startup issue, re-attach one device and then restart the PC. If this is successful, re-attach the next device and restart the computer again. Repeat this process until you find the device that is preventing the PC from starting properly. Contact its manufacturer for advice on this issue. Please, keep your PC software updated in order to possibly prevent the error from occurring in the future:
      • update Windows.
      • update the BIOS.
      • The software for the devices may need to be updated or reinstalled. Contact their manufacturer for information on the latest updates for your devices.
    May 21, 2008 | Computers & Internet
    Lack key appear on my flat screen
    Do you use the remote control or buttons on the tv itself? Many TVs have a child lock feature that will prevent operating the TV without the remote control. If you use the remote control you should be able to change chanels, and to disable the child lock from the menu.
    Mar 09, 2007 | Sony 21" Trinitron P202 Flat Screen...
    Washing Machines Logo
    11 people viewed this question
    Top Bosch Washing Machines Experts
    Tim Whalen
    Craig Butler
    Craig Butler
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
