Question about Rainbow Aquamate Carpet Shampooer
Why will my aquamate not release the water and shampoo?
When I turn the knob to let the water out nothing happens. The carpet stays dry, I may get a cople drops, but that is all
Agent Don
  • 310 Answers
SOURCE: Rainbow Aquamate 2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=620181
Rainbow Aqua mate 2 (by 3 users)
Posted by nicks mom on May 24, 2008
I cannot get water to come out of the water basin in order to shampoo. It is all connected correctlyXThis Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
2 Other Users Have the Same Problem Comment by deucedown, posted on May 26, 2008 Same problem here, I have only used the shampooer twice and water will not come out of the basin. I need to shampoo my carpets today and this is very discouraging. Somebody please help. I hooked it up and followed the directions. Comment by Angela31, posted on May 26, 2008 We are having the same problem. Everything is connected and no water is coming out. We have only used our Aqua mate 3 other times. Please help. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum / Aqua Mate. It has been a long time since I have operated a Rainbow Aqua Mate so I suggest that The best solution to operate the Rainbow Aqua Mate is to contact the Rainbow Tech Support line listed below or to contact your local vacuum cleaner dealer and have them send out a Rainbow Aqua Mate owner’s manual so that you can operate the unit successfully. By listening to the 3 questions listed above the actual water basin I believe is the recovery water tank to be emptied when full and I believe that there is a separately bottle or tank that the solution goes in order to dispense the water.
If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 12, 2008
advacak
  • 125 Answers
SOURCE: i don't have the aquamate
any shampoo made for extractor type machines will work fine, or mix liquid laundry soap 50-50 with water (after all, you AREwashing fabric}
Posted on Dec 16, 2008
advacak
  • 125 Answers
SOURCE: rainbow shampooer and frieze carpet
yes, it can be used without harm, but try a test area to be sure the dye is not cheap
Posted on Dec 23, 2008
RockyNR1
  • 324 Answers
SOURCE: aquamate II NOT WORKING !!
If this is pre-owned unit that you bought - it may be clogged. If people who had it did not rinse shampoo solution out of the system after using it - shampoo becomes thick and sticky when dry and may clog the tubes. Also it may impair the pump.
Pump may also be defective. It should make a humming noise while in operation. It is hard to hear when vacuum is on so take the Rainbow with water bowl of the white AQM basin, turn on the vacuum while AquaMate is still plugged in, put your hand on the black plastic on the white AquaMater water nontainer and you should feel pump vibrating inside.
If you feel it start with filling up the white tank and bottle with warm water, turn AQM on and try rinsing it. However if water can not get through at all - it will not help.
Then take the handle apart (a bit tricky but be careful ant to break the plastic and you will get it open). See if there are no clogs there. in tubes nor the VALVE.
If no clogs fing - you will have to acces the pomp and few short tubes inside this plastic box assembled onto the water tank. to get it open you may have to break off 4 latches that hold top halve to the bottom. You can purchase one HERE. Make sure that tubes inside are not bent at the sharp angle and obstructing the flow. If you need any tubing - you can find it cheap at Home Depot (have a sample with you so you pick the right diameter).
Clean all tues inside and you possibly will have to take the pump apart to get it cleaned. If it is not working you can buy one HERE.
Stil no luck - put EVERYTHING in a plastic bag or several bags and then in a box and ship it to us - we will get it running.
Good Luck,
Rocky
Posted on Mar 28, 2009
  • 41 Answers
SOURCE: New Rainbow aquamate. It is not letting the water flow through.
Sometimes it takes up to 10 or so minutes for the Aqua mate 2 to begin pumping out anything.
If it is the new Aqua mate 12 (the big blue one, that is like a giant power head) the same thing is true for it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Posted on Jun 13, 2010
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
Carpet cleaning
Carpet shampoo is popular way to clean your carpets. There are many different brands of carpet shampoo, so make sure that you follow the guidance on the label.
  1. Make up the solution as directed on the packaging. In many cases, the product will need to be diluted with water.
  2. Use just enough carpet shampoo to cover the area.
  3. Do not make the carpet too wet - not only is this a waste of detergent, but it's also going to increase drying time.
  4. Scrub on the particularly stubborn areas using a hard-bristled brush.
  5. Let the carpet dry.
  6. Vacuum the shampoo once it has dried.
Carpets and floor cleaning
May 17, 2013 | Vacuums
I need to know how to attach the aquamate accessory to my rainbow vacuum. It's a D4 C model
You should have a non-electric hose which you want to attach to the vacuum suction, then take the long skinny hose and hook it to you kitchen faucet. You may have to unscrew the end piece from your faucet. turn on youir hot water. On the handle of the aquamate, there is a little holder. Unhook it by releasing the yellow button. Put your shampoo to the line, no need to dilute, the Aquamate will mix the right amount to the water. Now you are ready to shampoo. You can pick up water until you hear the machine stress out. That is time to change the water in the basin. It is probably best to change it before that, but don't worry, the separator keeps it out of the motor. Hope this helps fixya! Thanks, Let me know, Rene (the Vacuum Doctor)
Nov 17, 2009 | Rainbow Technologies D4 Bagless Vacuum
Don't know how to use carpet shampooer
You should have the new aquamate, it has a blue top to fill with the water and water/soap solution that pops down into place. You will need to use your power nozzle hose and tube, connect it to your shampooer (make sure to connect the power connection just like the power nozzle). Fill your water up, large compartment is for cold water only and the smaller compartment is for one cap full of soap then the rest filled with cold water. Start with just a splash of water or an empty basin in the rainbow. The trigger will control your water spray and the brush underneath. There are two levers on the back of the shampooer marked with a shower head and a bar of soap. Use the soap with the shower head and the soap on and the water only with just the shower head on. You will want to also go over the area shampooed with both off to **** up the remaining water. Make sure to clean your floor thoroughly before shampooing.
Aug 13, 2009 | Rainbow E series Canister Wet/Dry Vacuum
NO WATER COMING OUT FOR SHAMPOOING /DUMPS WATER WHEN UPRIGHT
there is a belt inside that runs the pump to spray the water. I would take it in a have it replaced. Mine did the same exact thing.
May 25, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Dont know how to hook up the carpet cleaning part of the vacuum
You have to have the Aquamate II shampoo attachment in order to clean/shampoo your carpet. Go to the Rainbow website and you can purchase it if you don't already have one - if you do have one, this site also has simple directions on how to set up the Aquamate to shampoo your carpet.
May 11, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
Apr 13, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Water leaking from out of the heppa filter
Reasons for that to happen:
a) You have tilted the vac while vacuuming
b) Used the Rainbow without separator (basket like thing on the bottom of the motor)
c) Overfilled the rainbow tank with water (may have happened when shampooing with AquaMate)
Clean and install back the separator, remove HEPA, Set the Rainbow on empty water pan (with HEPA removed) turn it on for a while so everything will dry. Install new HEPA.
You will have to get a new HEPA filter (you can find them HERE)
Good Luck,
Rocky
Mar 18, 2009 | Rainbow E series Canister Wet/Dry Vacuum
I don't have the aquamate shampoo that is recommended for the rainbow e2 aquamate floor cleaner. what is safe to use with it?
Nov 26, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Aquamate Carpet Shampooer Logo
76 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
