Question about Kenmore 44722 Portable Washer Top Loading, 2.1 Cu. Ft
Kenmore 4472 error codes
Will not drain after a few minutes turns on the 12 10 and 6 lights and flashes the water level light, obviously an error code, what does it mean.
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
Why blinking lights, won't wash, drains water out?
Hello. You didn't provide any brand/model number but the flashing lights are most likely digital error codes flashing in a pattern. For instance, there could be the "clean" light flashing groups of 2 blinks and then 7 blinks or the "sensing" light flashing a certain number of times and then the "rinse" light flashing another number...these error codes will tell you where the problem lies. As a built-in safety feature, the unit will try to wash the dishes but when something fails internally, the program will stop, and then drain out the water, then flash the error code of the part that failed--for example, if the water temp was improper for a certain length of time, a motor pump failure, heater failure, water level wrong--there are many codes. Hope I shed some light on the problem!
Aug 18, 2015 | Dishwashers
After few minutes lights start flashing and the machine stops. when opened the water has not drained away?
Guessing you have a Kenmore HE? The flashing light is actually a code it is giving you. Your manual has the meaning of the code flashing and will tell you how to repair it. Count the flashes, then get your book out and go to "troubleshooting".
Mar 26, 2015 | Washing Machines
What are error codes
IT SOUNDS LIKE THE WATER IS NOT PUMPING OUT. IF THAT IS TRUE THEN I WOULD SUSPECT A PROBLEM WITH THE PUMP. YOU CAN GET PARTS AT APPLIANCEPARTS.COM
May 06, 2014 | Washing Machines
HF error flashes, then after 7 min. drains machine, but won,t go in wash cycle
Kenmore HE3T front loading washing machine. About every 2 minutes the cycle stops and flashes an "f" then an "h" on the display over and over again. **
That error code can be the result of no water detected entering machine after 30 seconds or pressure switch (water level control) activation not detected after 8 minutes of filling.
If there is no water in the machine at the time, make sure that both water taps are turned on, check for kinked fill hoses or plugged sediment screens in them and verify the water fill valve operation.
If there is water in the unit, verify drain pump and water pressure switch are operating properly, the pressure switch hose is in good condition and properly connected to the pressure switch. Also, make sure the water is not siphoning out of the machine prematurely due to an improperly installed drain hose
That error might also be caused by too much suds in the wash water like can result from using non-HE detergents
Nov 29, 2010 | Kenmore HE3T Washer
I have kenmore elite he3 and it is flashing f 02 and then it will flash sud. Water will not all drain out of it,
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 27, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE4t Washer
Error code F02 f the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the ?Sud? error will be displayed, then 4 minutes later the F02 error code will be displayed. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check the electrical connections at the pump and make sure the pump is running. ? Check the drain pump filter for foreign objects ? If the above does not correct the problem replace the pump
Sep 11, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 44722 Portable Washer Top Loading, 2.1 Cu. Ft Logo
Sal DeAngelo
fordexpert
Mike Carew
