Question about Konica Minolta Office Equipment & Supplies
How can i fix error message c-3721 on bizhub c360 machine
  • Konica Minolta Master
  • 6,674 Answers
If this code come back after this procedure get a new fuser, do NOT reset and Reset dealing with the fuser it can catch on fire that will ruin a perfectly good day
1.
Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Posted on Dec 30, 2015
taminol
  • 62 Answers
SOURCE: my brand new machine Bizhub 211 have paper jam problem
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Tam
Posted on Apr 26, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
  • 57 Answers
SOURCE: C-3721 error is displaying. How can I fix it?
Fusing abnormally high temperature detection (heating side)
Check the fusing unit for correct installation
Check the fusing unit, PRCB and DCPU for proper connection and correct or change as necessary.
Change fusing unit
Change PRCB
Change DCPU
Posted on Jul 05, 2011
  • 158 Answers
SOURCE: an error on my c360 konica minolta c-3721
fuser temp too high to reset turn off machine then turn on while holding down the utility/counter button when the trouble reset button comes up on the touch screen touch it and make sure it says ok then turn the machine off wait 10 seconds and turn back on if error code comes back fuser unit will have to be replaced
Posted on Feb 06, 2013
SOURCE: c3421 bizhub c360
fusing unit problem not heating up.generally replace.
Posted on Jul 11, 2013
After adding yellow developer in bizhub c360, the machine immediately start to give an error code of c2556 what is the problem and how to fix this... I real need your answer(shekinah.il1992@gmail.).
by adding manual developer, value changed, so try to reset many times and meanwhile add toner from service mode.
else need to change developing sensor chip
Apr 01, 2017 | Konica Minolta bizhub Office Equipment &...
How do I change the filters in my Bizhub C360?
what sort of filter is it. ozone filter then see this video for possible location it is a different model but it might be a similar setup on your machine. http://www.youtube.com/watch?v=ZQtatt-6gTM
If it is the dust filters on the toner cartridges then
http://www.youtube.com/watch?v=cNOlf43vdRE
Oct 27, 2014 | Konica Minolta Bizhub C360
What to do if Bizhub C360 will not turn on?
Power is ok out of the wall? different plug, plug is well connected to the machine? check it plug in tight. on surge protector get a new one. Main power switch OK any indicators on at all?
Jun 28, 2014 | Konica Minolta Bizhub C360
Bizhub c360 error code 12
l-12 or p-12 code????????????????????????????
Feb 07, 2014 | Konica Minolta Bizhub C360
An error on my c360 konica minolta c-3721
Dec 11, 2012 | Konica Minolta Bizhub c203 Copier
Change fusing unit
Change PRCB
Change DCPU
Jun 28, 2011 | Konica Minolta Bizhub c203 Copier
When quoting that error message, Konica told us the machine was disabled remotely by them.
Nov 16, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Trouble code c-3721 on konika minolta multi functional printer
was told this message meant Konica have disabled the machine remotely.
May 13, 2010 | Konica Minolta bizhub C250 All-In-One...
Print error page Bizhub C351
Google the full error.
this sounds like a font realted postscript error.
Jan 05, 2010 | Konica Minolta bizhub C351 All-In-One...
173 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
