Question about Mtd Products Yard Machines 158CC Tiller
The 15/16 nut that holds the blade on is locked tight.
The nut holding the blade on my MTD riding tractor is so tight I can't even budge it. Anyone have any tricks or tips ? Yes, I am using a 15/16 socket and rachet. Yes, I am securing the blade with a screw driver placed through the hole, to keep the blade from rotating. Hell, I even put some WD40 on it. Anyone ?
Had the same problem with my mower. Find a length of metal pipe that will fit over the handle of your socket wrench and it will give you more torque. The nut on mine would not even budge with a 12" extension bar, but when I put a 3ft steel pipe over the bar, it popped loose with very little effort. I also used a wood block to hold the blade tight
Posted on Jul 20, 2009
    Problem Solver:
  • 10 Answers
If you can get hold of a compressor & rattle gun, this will do the trick.
Posted on Jul 09, 2009
Changing blades on 2008 mtd rideon mower,are they left hand thread or just incredibly tight.
to remove the bolt or nut turn it the same direction the blade turns when cutting. This way the bolt tightens itself as it mows not back out and slip.
Dec 15, 2016 | Mtd Garden
LT2000 craftman mower bolt and nut that tightens blades keep coming loose
Get some red lock tight and put it on the spindle shaft threads. Sounds like the threads are worn down and just won't hold the spindle nut tight any longer.
Jul 02, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn mower blades won't budge, even w/ 1/2' drive impact wrench
Hi, warm the nuts up with a heat gun or oxy torch then try the impact gun while they are hot, regards Phil.
May 31, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
Blade will not lift..
Make sure that all the pivot points are greased or oiled sufficiently and not rusted. Also make sure that the pivot points are not to tight and binding. If so loosen a little they should have cup washers on them or nuts with plastic inside them so they will hold the joint but not fall off. Good Luck...
Oct 02, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
I cannot seem to be able to remove the mower blade pulley wheel. I am replacing a damaged mower deck with a new one and need to remove the blade components from the old deck. The nut holding the pulley...
With the blade on and tight, block the blade with a piece of wood or someother means of securing it so it will not turn when you try to remove the nut. I then use a fifteen inch breaker bar and "massage" the bar with a four pound sledge hammer. A few moderate taps and it starts to loosen.
I hope this helps you get it off.
Aug 27, 2011 | John Deere Garden
Hi , having trouble changing mtd 38
lefty loosey...use a block of wood to wedge the blade against the deck, and use a ratchet and extend it with a piece of pipe...the get real tight over time...an air gun or other impact gun works the best...
Apr 26, 2010 | Garden
I need to replace the shaft that connects to the blade on my Craftsman?s Riding Mower 42?. The problem is the star that holds the blade is place has smoothed down. So, I cannot use the blade to hold the...
You can use the belt to hold the pulley from turning
( you ARE going to replace the belt aren't you?)
Simply use locking pliers (vise grip) to clamp the belt sides together close to the pulley. Then wra the other other end of the loop around something convenient to keep the pulley from turning. Guaranteed to hold the ******.
Oct 03, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
I have an older mtd yard machine that throws the belt whenever the engine is started. It appears that the belt is very tight the blades turn free when the belt is not connected so they are not locked up....
I had an MTD riding mower, when the mower started the belt should not have been engaging the blade spindle. They're is a clutch lever which goes down to a simple spring tensioner which engages the blade. You may have the tensioner misaligned which will allow the belt to be desheaved. My old manual told me to hold a straight edge along the engine pulley and the driven pulley, like on a table saw. There should be some deflection in the belt, 1/2" over two feet.
Apr 28, 2009 | Garden
Have a 12 inch tradesman miter saw and can not change the blade
the nut maybe a left handed thread. the norm is righty tight. lefty loosy, try the oposite.
Apr 09, 2009 | Saws
Mtd Products  Yard Machines  158CC Tiller Logo
454 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
lnbn1975
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
