Question about Xerox Phaser 6360 Laser Printer
Replace ram on xerox 6360
Need to replace RAM
  • 2072 Answers
SOURCE: Xerox 6360 will not recognize replacement toner
Only two things I can think of.
1 Be sure you have removed all the seals that are on a new cartridge. The tape etc. Sometimes a piece of one of them rips off.
If you have all the packaging seals removed then return the cartridge because its defective.
That machine can take up to 3 minutes to recognise a new cartridge. So if your turning it on and off quickly, let it set up for a few minutes.
Posted on Dec 31, 2009
Testimonial: "This should help"
lawdog81
SOURCE: xerox phaser 6360 is ghosting.
Most common cause of this is the use of 3rd party toner. This isnt true for all printers but some of the newer Xerox are notorious for it as the 3rd party toners are not produced to the exact specs as xerox. If your not using genuin Xerox toner you have your cause.
If your mechanicaly savy you can completely dissasemble most of the printer in order to clean out the toner. Then start over with new Xerox toner cartridges. I have had to service 2 of these printers in this way, and both were like new when done.
Posted on Feb 11, 2011
  • 360 Answers
SOURCE: Xerox Phaser 6360 The unit keeps
Replace photosensitive drum, which is a consumable part & has to be replaced when it is at the end of life.
Posted on Aug 16, 2011
  • 106 Answers
SOURCE: I have a Xerox Phaser 6360 with a ram error what could the problem be?
Are you sure it is not a NVRAM error you are recieving?
If yes, remove the IMAGING UNIT.
Close the door and Power On.
Msg gone? If yes, replace IMAGING UNIT.
If no, remove the FUSER unit.
Close the door and Power On,
Msg gone? If yes, replace FUSER.
If not, it is the ENGINE BOARD.
Posted on Oct 24, 2012
SOURCE: xerox phaser 6360 imaging unit stuck
The lid lifts a lever on the right side of the printer that moves a set of gears that releases the imaging unit. If the lever is broken or disconnected, it will not release. You may have to remove the right side panel to resolve it. You have to release the top, by removing 4 screws, and then the panel will release.
Posted on Oct 31, 2012
Xerox phaser 6360 smearing magenta toner only
that's the developer assembly that has gone bad. If you're using 3rd party toner it wears down a lot quicker. You'll need to replace the magenta developer unit, part number is 848K03850.
http://www.iteminconline.com/848k03850_848k03850-xerox-6360-developer-assembly-magenta-oem-new-genuine.htm
Feb 09, 2016 | Xerox Office Equipment & Supplies
How to replace the main drive assemble gear on a xerox 6360
Remove the top cover, remove the right cover, disconnect the cable, remove the 4 screws that hold the main drive in place and remove.
Aug 15, 2014 | Xerox Phaser 6360 Laser Printer
Just put in a new imaging unit to a xerox phaser 6360 and now everything is pink... any ideas how to fix?
Check which colour you replaced and check that everything is seated correctly.
Good Luck.
Jul 22, 2014 | Xerox Phaser 6360 Laser Printer
I have a Xerox Phaser 6360 that one day just stopped printing yellow, despite having plenty of ink. Xerox told me I needed a new imaging unit, so I replaced it, but it didn't help. I put the old one back...
Your machine uses solid ink wax blocks. So no calibration is necessary. Does the self test print look good. I suspected not.
Check out the Xerox.com website. It could be a problem as you machine is no longer sold.
Sorry.
Oct 16, 2013 | Xerox Phaser 6360 Laser Printer
Not printing cyan on xerox 6360
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 22, 2013 | Xerox Phaser 6360 Laser Printer
Oct 24, 2012 | Xerox Phaser 6360 Laser Printer
Xerox phaser 6360 imaging unit stuck
May 18, 2012 | Xerox Phaser 6360 Laser Printer
Phaser 6360 white lines in the print
Looks like you need to replace the imaging unit. Unfortunately, this an expensive consumable
May 13, 2012 | Xerox Phaser 6360 Laser Printer
Xerox 6360 control panel blank
If your Xerox Phaser 6360 has either garbled characters, inverted or upside down display, or no display, the control panel is most likely bad and must be replaced. Here's a video on how to do it and where to get it. Hope it helps!
Mar 30, 2009 | Xerox Phaser 6360 Laser Printer
Market projection and price of of this product Xerox phaser 6360
50,000 pages a month and depending on features, $1400 to 3000.
Feb 02, 2008 | Xerox Phaser 6360 Laser Printer
Xerox Phaser  6360 Laser Printer Logo
41 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
