Top Notch Air Conditioner model AUS09H53F010L4 is not coming on and showing error code R8
The air con is responding to the remote and not coming on but showing error code F8.
    Novelist:
    Champion:
  • 373 Answers
Suction temp, sensor of compressor.
1. Check whether the resistance of sensor is normal, otherwise replace it.
2. Check whether the sensor wire is shorted out or if it open circuit,and whether the plug is well contacted, Whether there is welding off or rosin joint on the electric control board . Repair it if there is any above.
3. When the 1 and 2 are both normal, Then the components or integrated circuit is damaged, The controil board should be replaced.
Posted on Jul 02, 2014
bobotfel
  • 236 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
burzerko
  • 254 Answers
SOURCE: air-conditioning; error code: 425
Try Samsung.com
Posted on May 30, 2008
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
  • 400 Answers
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Posted on Mar 04, 2009
  • 10 Answers
SOURCE: I have a model AR DL10 remote for a Fujitsu air
After changing the batteries you have to depress the RST button and if the remote has the abcd slide switch ensure it is set to A.
Posted on Jul 15, 2010
Testimonial: "THANKS"
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
Why my mitsubishi air con blinking 6 times ?
that is only half the code you need the remote an lots more steps to troubleshoot that conditioner
here is some simple steps . but id get help on this.
http://www.daikin.com/products/ac/services/troubleshooting/
after that comes this step an its exacting
AstiquerMold Control Air con Specialist
in that page at the top is the command for your unit to ask it what code its tossing.
Jan 05, 2015 | Mitsubishi Heating & Cooling
Does any one have a Digital Sanyo air conditioner remote rcs-ks-1 for sale ?
If Sanyo cant supply one, try any Air con parts store or electronics store. There are universal air con remotes on sale that you programme in to suit your make / model.
Jun 26, 2014 | Sanyo Split System Air Conditioner
Digitech ar 1731 Air conditioner remote. I need code for Fujitsu AC Model AST12LSBCW please
Fujitsu Air Con codes for the Digitech AR1731 Universal Remote Control for Air Conditioners are:-
1152
0464
0127-0137
Dec 12, 2013 | Televison & Video
After I changed the battery of the remote the AC will not respond. I have to turn on the AC manually. T
dear sir
please turn off the switch of air con and after two minut turn on, your main electric soures for reset the settings then it will show to you on it,s display Green light. it is sign of power supply after that you can use your remote control with your air con,
hope answer the question
thank you
please vote!
Sep 25, 2010 | Fujitsu 24C1 Air Conditioner
My new gree air conditioner split system has an E1 error
My greewall mounted has a e1 prblem.how van ifixor what is the problem
Feb 09, 2010 | Heating & Cooling
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
