Question about Rowenta DG8430 Pro Precision Steam Station
Steam button broke?
The steam button no longer engages, as if the plastic on the inside of the button that depresses to allow steam to flow has been broken off. Is there a replacement part for this? Thanks!
    Genius:
  • 1,114 Answers
I've looked up parts for this iron. Sorry to say the steam button is not listed. The button may be able to be repaired at a small apliance repair center, but I do not know what the cost would.
Posted on May 07, 2014
57 varieties
  • 1653 Answers
SOURCE: when using the steam it spits out sediment on the
This happens due to limescale and / or build ups of mineral deposits such as iron in the water. You will need to use a kettle descaling solution or an iron descaling solution available from most supermarkets or home appliiance stores and clean out the debris in the iron. It happens to most if not all irons and cleaning on a regular basis is the only answer or use very expensive 'iron water'
Posted on Sep 28, 2009
SOURCE: Steam button not working
I had the same problem. I found the trigger button at SmallAppliances.com. You'll have to pry off the rubber grip, and unscrew one or two screws on the handle, bu the trigger inserts neatly into the space. Screw it back together, snap on the rubber grip and it will work like new. Below is the part number & price.
Rowenta DG0123 Knob Trigger, Blue $9.99 (plus shipping)
Watch out, the next thing that will go is the on/off switch. Once it starts getting difficult to turn the unit on or off, just plug and unplug it until you get the new part, or you will be stuck one day and need the iron and go to turn it on and it wont start.
The part is $20, and the same site has it available.
Posted on Feb 24, 2009
snakehead
  • 1074 Answers
SOURCE: steam button wont push down
take down and clean the parts where the steam button is the spring could be dead and needs to e replaced.good luck
Posted on Apr 18, 2007
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
  • 447 Answers
SOURCE: no steam
What you need to do is clean out the steam orifice. (The tiny hole the steam comes out) When water is turned to steam it leaves behind mineral deposits, (Iron, Calcium) Especially if you have "hard" water in your area. Here's what you do. Add some CLR, (Calcium,Lime Remover) to the water you put in the iron, let it sit a while, laying flat, then drain the water out. You want to get the nozzle, to, holding the iron upside down, try to immerse the steam nozzle for a couple of seconds in the CLR or drip some directly on it. You can buy this product in most stores. It works well and fast. Dip your showerhead in it too, you'll be suprised at how it improves water flow. It is safe as long as you follow the instructions.
Posted on Apr 06, 2010
Digital settings flashing
Breville VIN170 Extreme Steam Digital Steam Generator Iron, unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on.
Below is a link to the user manual for the Iron
http://www.breville.co.uk/downloads/dl/file/id/378/steam_generator_iron_vin170_instruction_book.pdf
Hope this helps, if you require any further assistance please contact me.
Oct 18, 2014 | Breville Vin170 Extreme Steam Digital...
Parts for Model DG8030
Google Rowenta repair. They have stations all over the US.
Jul 25, 2014 | Rowenta DG8030 Expert Pressure Steam Iron
Filter light flashing what do I need to do no manual available
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
Sunbeam steam valet instructions
How to fill your Sunbeam Steam Valet
Here is how you fill your Steam Valet. Press the small button on the back of the handle and pull bottom of handle apart from the top half of steam valet. Then take off the white cap on the inside of the handle and fill with water to top. Place cap back onto the opening and slide handle back and click in place. Plug in and you're ready to steam within a few minutes. If it spits out water let heat up a little longer if that doesn't stop it then tie a thin cloth over the top part where steam comes out to keep the water from spitting out onto your fabric. Hope these instructions are clear enough. More questions about this iron go to www.manualslib.com.
Feb 29, 2012 | Sunbeam Irons
Steam Button Sticks in
vinegar the iron its calcified,it will clean out
Sep 30, 2009 | Euro-Pro Shark Rapido Electronic Iron -...
Tefal Pro Express - Constant Steam
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
Jan 04, 2009 | Tefal Ultraglide 1549 Iron
Tefal Pro Express
  1. solenoid valve blocked
  2. swich for steam broken
  3. you forget it in turbo steam mode and you have steam all the time
ps see below on link turbo button
http://www.gostore.com.au/~ebay/krups/tefal/proexpressturbo/TefalProTurboAuction(3).jpg
Jun 22, 2008 | Tefal Ultraglide 1549 Iron
Thanks J
Feb 10, 2008 | Rowenta Steam 'n Press DA75 Iron
Won't steam
The steam irons I have see have a separate button to allow water from the reservoir to enter the steam chamber. This button latches down for steam and you unlatch it for dry. Also, there is a temperature range on the temp dial for steam.
The reservoir must have water in it for the iron to make steam. If calcium from the water has built up on the reservoir valve, it may prevent the water from entering the steam chamber. Straight white vinegar instead of water may help.
Nov 02, 2007 | Toastmaster 3302 Iron
Rowenta DG8430 Pro Precision Steam Station Logo
218 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
