Question about Music
Have a powerbank P8002 amp. Whoever hooked it up hooked it up with toogle switch. It powers on but has no effect to sound on or off
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Line 6 how do i get it to work
Line 6 connected to AC power and LED showing power to unit. Guitar into effect input, effect output to guitar amp. Does guitar make sound through amp in bypass mode? No then check cables...yes then use foot switch to turn Line 6 effects unit on. Adjust control knobs for desired effect levels/settings.
If pedal provides no effects...off/on switch defective or internal electronics in need of repair.
Oct 26, 2012 | Line 6 DL4 Delay Modeler Effects Guitar
What do you hook up first, mixer or power amp oreffects in a rack system?
Effects plug into mixer, mixer plugs into power amp. Others may want the mixer and the effects plugged into the power amp for the most available inputs. (when multiple inputs are available.)
Effects and mixer are a line level output and the mixer can be considered a line level input as well. A mic mixer has gain amplifiers for the inputs that are below line level such as unamplied microphones. It is possible to parse to absurdity, but the gist of it is above assuming you do not want to apply the same effects to everything all at once.
Feb 06, 2012 | Soundcraft Efx12 12-channel Mixer With...
Hey my Pyle pro heavy metal distortion peddle isn't working. Everythings fine until I switch to distortion, than no sound comes from my amp. Any suggestions?
Check the switch to see if it is functional with an ohm meter. Also check length of plug and make sure it engages the jack securely as there are about 5 different lengths of 1/4 inch jack available. Are the effects powered by battery or through the amp, or on thier own power?
Jan 27, 2012 | Music
I need schematics for this amp. know where I can get them?
Josh,
I also need schematics for this amp. How about whoever finds it first shares with the other?
Cool, Thanks,
bob at stumpweb.com
Jan 27, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
I have a Marshall MG100HDFX 100-Watt Amplifier half stack (solid state) and I now am not getting ANY sound out of the amp. I changed the fuse and the power module behind the fan, and still no sound,...
plug headphone in the effects send jack...If you get somme sound (won't be too loud) there, that means preamp sections are probably ok. Drive a signal into the effects return jack... If power amp responds, it is OK... If both these are OK, then suspect the switch contacts on these two jacks that forward the preamp to the power amp when effects unit is NOT plugged in.
These contacts are a chronic problem.
Sep 19, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Guitar amp shows power but has no sound, could it be a blown fuse
Nine times out of ten, any problem with an amp having no sound coming out, it's a wiring issue. Make sure all of the wires internal to the amp are propely hooked up. Also, try switching out the quarter inch cord you are using from your guitar to your amp. Could be a bad cable. Unless you have blown the speaker completely, something is loose or not hooked up properly.
Feb 27, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
After hour of playing the amp starts the effect popping sound
there is an open connection, most likely right off the input jack ,causing this issue. Resolder it or retension the jack connection.
Jan 29, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Music Logo
20 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
