AC Delco Fuel Pressure Regulator 2001 GMC Jimmy Fuel Pressure Regulator AC Delco Logo
Sara Anderson Posted on May 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the fuel pressure on a 2001 gmc jimmy supposed to b?
Joel Friedenberg
Level 3:
  • Master 1,114 Answers
  • Posted on May 07, 2014
Joel Friedenberg
Master
Level 3:
Answers
1114
Questions
0
Helped
440577
Points
3272
The fuel pump should be putting out 55-60 psi.
bigjoet_1989
Level 1:
New Friend:
  • Contributor 11 Answers
bigjoet_1989
Contributor
Level 1:
New Friend:
Answers
11
Questions
Helped
4416
Points
37
The fuel pressure for the v6 in the jimmy should be 60 psi
3helpful
2answers
Does anyone have a video on fuel pressure regulator replacement?? 2001 GMC Jimmy
FPR, 4.3L
SM quote
the fuel pressure regulator, part of the fuel rail assembly, keeps the fuel available to the injectors at a regulated pressure. A separate pipe returns any unused fuel to the fuel tank.
The fuel meter body assembly?(1) attaches to the lower intake manifold. The fuel meter body assembly performs the following functions:
  • Distributes fuel evenly to the injectors?(12)
  • Integrates the fuel pressure regulator?(14) into the fuel metering system
here it is right here #14
Getting fuel everywhere except fuel injectors
You really need a garage to diagnose why. You may have insufficient fuel pressure, or the injectors may be blocked if you have been running the tank low.
But first, check this fuse in the Engine Bay
ECM ICiN PCM/VCM Ignition, Injectors, Crank Sensor, Coil Driver Module
https://fuse-box.info/gmc/gmc-jimmy-1995-2001-fuses-and-relays
Low fuel pressure is mentioned here
https://www.google.com/search?q=96+gmc+jimmy+won%27t+start
Good luck with the move Tammy
Why does 2001 gmc jimmy won't start unless primed why won't 2001 jimmy start
you say it won`t start unless primed I take it you have to supply a fuel source. if so check fuel pressure as the pump maybe failing.
I have a 2001 GMC Jimmy 4WD. I cannot fill up my
Those hoses are located in the same area as the tank filler. There is a set of hoses that go from the gas cap connection to the tank. You have to lower the tank.
2001 gmc jimmy acceleration problems
Have you checked base fuel pressure at the injectors ?
Base fuel pressure when cranking or at idle should be at least 60psi or more.
1992 gmc jimmy 4.3 vortec hard to start
Bad fuel pressure regulator under the intake manifold
& possibly a fuel pump loosing pressure also
2answers
Will turn over but it wont start
What is the fuel pressure? these trucks need a certain amount of pressure to start, if low just 3psi it will not start, if you are sure the pump is good then you may bad spider injector. check fuel pressure first and also try spraying starting fluid into throttle body and see if truck starts. the pump needs 60 -66 psi to start the truck.
Fuel pump pressure specs for 2001 gmc jimmy
see the indication for manufacturer specification which is the pressure.
of fuel pumps.
God bless you
I have a 2001 GMC Jimmy and I was driving and the car just stoppe
fuel pressure should be 55 to 61psi. could be a cloged filter or pressure reg
Wont start no fuel pressure
this vehicle needs 60 lbs of fuel pressure to make the popit type fuel injectors to open you need to check with pressure gauge
Top AC Delco Fuel Pressure Regulator Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you an AC Delco Fuel Pressure Regulator Video Game Console and Game Expert? Answer questions, earn points and help others
