Yes i have a tantus samsung 40" tv and my problem is that the colours are out of alignment red green and blue so your almost watchonf 3d almost can this be rectified can it be fixed
    Scholar:
  • 195 Answers
If this is a tube set--and it sounds like it it--it likely needs convergence chips. IF the color and picture was ok before this happened--it is worth a look, but if it was getting dull and fuzzy, BEFORE the convergence problem--it needs tubes and is NOT worth repair.
Posted on May 08, 2014
SOURCE: Samsung tantus 1080i
hi i have a 47" samsumg tantus tv and i haven problem with the screen. has some red lines
Posted on Mar 11, 2008
Slinteriors
  • 8617 Answers
SOURCE: Philips 55PW9363 looks 3d
You need to replace both convergence ICs they are STK392-120 this is an easy repair that you can do yourself and save yourself around 400.00 for about 45 minutes work. You can order the new ICs at the following link and they provide free installation instructions with pictures and also free online support with a support tech while you do the repair. I am one of their support techs. You would also want to order at least 4 convergence resistors and they send the proper ones for your model as often a couple resistors go. Your model uses 6.8ohm 2watt 5% metal film resistors. So to recap you will need (2) STK392-120 Convergence ICs and (4) Convergence ICs . very inexspensive repair if you do it yourself. here is the link.
http://servicemanuals.vstore.ca/
Posted on Apr 12, 2008
yankeegurl
  • 121 Answers
SOURCE: TOSHIBA 65H82
you need to replace your 2-convergence ic's #STK392-110 you need to replace both ,,they are attached to 2 big heat sinks and identified as q-751 & q-752 you can get the ic's you need plus free tec support and installation instructions including pictures at the link I gave you.
localwonder
  • 6784 Answers
SOURCE: 3D TV Blues, Greens, Red and a little yellow. RCA Modle # R52WH74
This is called convergence board failure. try to re calibrate the convergence. if the re calibration fails, this means your convergence board will need to be replaced or, rebuilt.
Posted on Feb 13, 2009
ladywinn
  • 5138 Answers
SOURCE: picture is in 3d and green red blue
replace Both of your convergence ICs They are big black chips will have STK# on them also in same circuit there will be two low ohm resistors that might be bad 2.7 ohms CK them .
Posted on Jun 03, 2009
Hello tv has warped bottom and top screen on a rear projector samsung and blurred vision with red,green blue colurs not aligned tried to tune to no avail Samsung rear projector tantus sp42w4/42w5
The colors tell me of a convergence IC issue, warped bottom and top tell of another.
see this page on reparing the convergence problem yourself
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
also compair the before and after pictures to see if this is the other problem your having.
Then you have another fault, which im not completely sure of right now. I will look into it.
Oct 27, 2008 | Televison & Video
My picture has broken into colour ghosting (it looks like a 3d picture without the glasses on). I'm guessing that this might be the failure of one of the colour bulbs. The wavey colour bands that I see are...
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 31, 2011 | Hitachi 57F500 57" Rear Projection...
Tv showing two pictures. it is blurry and mostly blue, red in colour
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | Toshiba 42H81 42" Rear Projection...
Samsung Tantus (SP-43J8PF) Has Green Tinge - Easy fix?
You may try to get into the service menu and adjust screens/drives level(procedure below). But first turn the color off completely and adjust you brightness to mid-range, what you`ll want to do is a grey raster or bring it as black and white as you can while adjusting the red/green /blue guns or tubes. Also get a piece of paper and pen because you`ll want to record the original values of the items you may change. You want to go into the adjustment menu. Hope this will help Good luck
In quick sequence on the remote press:
MUTE - 1 - 8 - 2 - POWER buttons.
The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
Select the function and use the VOL+ button to enter.
Save settings and exit by pushing MUTE twice then POWER .
Nov 19, 2009 | Samsung PLH403W 40" Rear Projection...
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Colours are out
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Mar 10, 2009 | Toshiba 42H81 42" Rear Projection...
Colour problem with rearview projection tvred
you will need to change out the convergence board if the blue and green wont align its time for a new board
Aug 21, 2008 | Sony KP-51HW40 51" Rear Projection...
Feb 17, 2008 | Hitachi 57F500 57" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
