Question about West Bend 55108 Espresso/coffee Maker
Every time I meke coffee my machine have swill sound and don't make full amount of coffee
    Genius:
  • 1,114 Answers
Many times when a coffee machine is not working properly, it needs to be cleaned. Pour 1/2 & 1/2 White vinegar and water into machine as if you making the coffee, and turn machine on. It make two treatments t clean out the machine. You can then use some baking soda in water to neutrlize the vinigar.
Posted on May 07, 2014
There are 3 buttons to brew with and you get different amounts of coffee for each button. Lately the last button on the right gives the same amount of brewed coffee as the 1st button so if I want a full...
just plug it out from the wall current for about half day so that the coffee maker can reset itself then plug it in back.if that does not work that means the timing transistor is faulty.you will have to have it repaired.good luck.
Sep 25, 2011 | Keurig Special Edition B60 Coffee Maker
WHEN BREWING A CUP OF COFFEE, ONLY A SMALL AMOUNT OF COFFEE COMES OUT. I HAVE TO REPEAT THE PROCESS 4 TIMES TO GET A FULL CUP OF COFFEE.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 31, 2011 | Keurig B50 Coffee Maker
Gaggia Titanium - the button for a small coffee has stopped working. Can I do anything to fix it?
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that didn't fix it you might have a bad flow meter.
Jun 23, 2011 | Gaggia Titanium Espresso Machine
How do I clean the coffee maker? It is dripping very slowly.
this happend to my coffee maker not to long ago and all i did was unplug it part fill the warter well swill it arround loads ( might need to do this a few times ) and then empty it down the sink. I then (without coffee in it) filled it up and let it run through as if it was makeing coffee once and this seemed to work. Hope this is helpfull.
Jan 26, 2011 | Cuisinart DCC-1200 Coffee Maker
We poured the amount of water needed to make the amount of coffee desired but 30 minutes later no coffee was made. Does the bottom "warmer" button need to be on or does the maker just need to be...
The tank inside holds about 2 and a hlalf pots of water. Once the tank is full, whatever you pour in will come out. The unit has to be plugged in to make coffee. Leave a pot under the brew funnel and pour a pot of water in. If nothing comes out within a minute, pour another pot of water in. Still if nothing comes out do it again. This time for sure water will come out. It will take avout 10 minutes to get hot enough the first time it is full to make coffee. If you have a thermometer, the water should be about 190 degrees F to make coffee correctly.
Oct 28, 2010 | Bunn VPR Coffee Maker
How do I increase the amount of coffee dispensed on the large cofee setting. At present the amount is small
Push and hold the button for the coffee you want, but hold it all the way through the process. Don’t release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
Sep 20, 2010 | Saeco Royal Professional Espresso Machine
Hi, I have a Saeco Incanto and both short & tall selections give the same very short coffee. It is very nice with crema but very very short. How can I increase the dosage? There doesn't seem to be a...
Hi
Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don’t release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
If that doesn’t fix it, then you might need a new flow meter.
Aug 24, 2010 | Saeco Vienna SuperAutomatica Coffee...
Too much water is dispensed resutling in a weak espresso. This happened after rinsing the brew unit. Greatful for any assistance with this. I have a 1 year old Titanium.
Hi
Try reprogramming the button that is dispensing to much.
Jul 20, 2010 | Gaggia Titanium Espresso Machine
My nespresso does not make a full cup any more
Another good solution, though the previous one was good, is that you can factory reset the cup sizes. All you have to do is switch the machine off, and then press and hold the large cup button. After about 10 seconds, keeping your finger on the large cup button, switch the machine on -- then let go of the large cup button after about two more seconds.
Aug 15, 2009 | Nespresso Essenza C100 Espresso...
Won't make coffee
Could you please advise how I obtain a manual for a Saeco Magic deluxe
Apr 28, 2008 | Saeco Magic De Luxe Espresso Machine
West Bend 55108 Espresso/coffee Maker Logo
69 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Steve
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
