When bake selcted, hear clicks but does not light. can hold lighter when clicking and lights.
SOURCE: Our Whirlpool Accubake oven electric
The ignitor started working after I disassembled the cover and put it back...Thank you for your followup...Paul...
SOURCE: gas oven not lighting
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
SOURCE: Whirlpool GS563LXSS: bake and broil doesn't work.
Oven suddenly stopped to work.
After trying to turn on "bake" or "broil" I can hear couple clicks but nothing else happens.
No flame/no gas is coming out.
SOURCE: Gas range (10 y.o.) clicking
Has the tenant confirmed if all the ignitors are working or just the stove burners? What about the oven burner?
Please provide model no. of the kenmore range so that I can provide some better solution.
SOURCE: My Whirlpool SF367LXSS oven does not work on bake
Hi, Check the gas valve to see if it is getting power to open it....if it is then it has gone bad... The ignitors can also cause this but not likely that both will go at once... Also many oven/broilers have a separate regulator and that could be locked up... often because of high incoming gas pressure... heatman101
