Question about Paragon 8145-20 Defrost Timer
Defrost timer 8145-20 goes to defrost end fans go out end heather go in but compresor will not stop
Tem. inside 28 low side 26 hi is 302 walk-n frezzer r404a
    Top Expert:
  • 3,698 Answers
Is this a hot gas bypass defroster with a switching valve? If so, the compressor should be on.
Posted on May 07, 2014
The refrigerator side is not working, but the freezer is on my side-by-side
http://www.applianceblog.com/manuals/16025628.pdf
Here is a manual with decent infomaiton and troubleshooting tips. Since I can't walk you through each step of the troubleshooting process and see the results on the meter, I hope this will help you some.
Are you getting an ice build up behind the panel in the freezer compartment? If you are then check out the defrost heater, defroster thermostat and the defrost timer.
Since the cooling unit is on the freezer side, it moves the cold air to the refrigerator side with a fan and cooling tubes. If the tubes get blocked or the fan stops working then the refrigerator side will not cool down.
Please feel free to ask anything you don't understant and I will do my best to answer you.
Jun 10, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
The compresor runs but the inside fans do not. the box is getting warm
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 21, 2010 | Frigidaire FRT18S6AW Top Freezer...
Kenmore 52532101 side by side freezer and refrigerator not cooling - any suggestions? Doesn't appear to be frozen up.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Amana Bottom Freezer 7 years old running but not cold.
How to check stuff>
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover inside the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
heavy frost-
Aug 25, 2009 | Refrigerators
Ge side by side is freezing in the back of freezer, I have to defrost once a month. How do I check what parts I need and how to fix it
How to check everything
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
Freezer will not auto defrost , coils icebound
The problem is in the defrost timer , heaters or the defrost terminator ,most of the cases is in the timer you can turn it until the compresor off and if the coil is frozen the heaters will came on if this happend the timer is bad but if the freezer coil is frozen and after you turn the timer to the point that the compresor goes off and the heaters won't kick on it means that the heaters are bad or the defrost terminator fail .YOU can check the heaters for continuity and replace the one thats open or you can buy the deefrost kit which came with the heaters and the deefrost terminator.
Apr 18, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Paragon 8145-20 Defrost Timer Logo
74 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
