Question about Fisher and Paykel Fisher & Paykel Washer
Why is the hot water inlet leaking water - Fisher and Paykel Fisher & Paykel Washer
  • Fisher and P... Master
  • 3,247 Answers
Please refer later post on this topic.
Posted on May 07, 2014
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
What does "HC" mean?
The HC code indicates that the computer thinks the cold water inlet is getting hot water. The hot water inlet has the cold water coming in. Take off the inlet hoses and double check your water lines. If needed, swap the connections. While you have the hoses off, clear the filters and check for leaks. Check the flow rate and replace the hoses if the water flow is restricted. (Anti-burst hoses can reduce the flow when they detect a leak.)
If the hot water supply is correctly connected to the hot water inlet, then the electronic control board is getting faulty information. Unplug the washer for several minutes. If the code repeats, then the valve may be faulty. Alternative causes of the problem are the hoses, the wiring or the control board.
I hope this helps.
Mar 16, 2016 | Whirlpool WTW6400SW Cabrio Washer
I have a problem with a Samsung washer b1445s its leaks water from the intenal depenser tray, from the spare water inlet for hot water (not used cold fill only), it only leaks when filling for rinsing...
There can be a leak on the section where the hot water line inlet is connected. You can plug this hole using various types of fixers available in any hardware stores which can solve the issue.Removal and fitting back is the most important part as care must be taken to mark all parts removed..
Jan 06, 2012 | Kenmore Washing Machines
Rheem water heater 40 gallon,... found water on the floor,. traced it to the top nipples hot cold and pressure valve, water collecting at the base of these, inlets/outlets...?... Hmmmm.
Often the hot water tanks will begin to leak at the weld around one of the inlet/outlet holes....
the tank will need to be replaced as they is no way to repair that...
heatman101
Sep 18, 2010 | General Electric Water Heaters
Water leaks through hot feed into machine and eventually out of door when machine is not in use. it is a slow leak taking several hours to fill up
This most likely means that the hot water fill valve is faulty and not shutting off fully and needs replacing. This is a fairly simple and cheap job which you can do yourself or call in a repair man.
Oct 25, 2009 | Hoover Washing Machines
I have a ge washer wpsr3120w0aa that leaks water when rinsing
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
©2006 Publications International, Ltd.
If an inlet valve is faulty, check the water connection and the
valve screens. Try gently tapping the solenoids;
if this doesn't work, replace the inlet valve assembly.
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Troubleshooting Water Leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
Aug 29, 2009 | Washing Machines
No hot water coming out of any faucets
Hi, First thing you need to check is that the hot water valve might have turnd off. What you can do if the valve is on, Turn the machine on and set it for hot water only. If you can here a faint hum, then the inlet valve on the machine is probably plugged with sand. Turn the hot water valve off and remove the hoses. Look into the water inlet valve and there you will see a fine mesh screen. This might be plugged. If the screen is plugged, be careful and just scrape the sand out or you can flush it out by using the inlet hose and turn it on with short spurts. You will get a little water on floor but, it is effective.
If there is no hum or there is no plug, the inlet valve is probably bad.
I hope this helps. If so, please rate my answer so that I know how I am doing.
Thanks,
Vic
May 10, 2009 | Washing Machines
Fisher & Paykel GWL11 Leaking water
If you cannot see the water leaking from the inlet valves, check the seal just above the water pump located directly under the drum. I am in the midst of awaiting parts to fix this very thing on my FP GWL11. This leak is dripping water directly onto the motor, causing it to trip the circuit breaker during drain/spin cycles.
Note... I have also had to have the inlet valve assembly replaced as well as it was not opening to allow cold water to mix with the hot.
Hope this helps.
Apr 29, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
