Question about Toys
How to fix the lower blades of ModelArt 3.5 channel RC Helicopter
I have just bought this helicopter. And it was low on battery so I charged it, but not for so long, as I was very much eager to play with it. After sometime, the lower blade stopped rotating. I can rotate the blade myself though and its gear also does rotate when I do so. What may be problem? Is the motor for that is defective?
    Problem Solver:
  • 9 Answers
One of the other gears in the blade have probably been broken if the blade has been held or stuck when trying to fly. Might need to replace gear.
Posted on May 08, 2014
  • Kakar Nyori
    Kakar Nyori May 08, 2014
    Thanks for the help. So, I disassembled it, and one of the motor (for the defective blade) gets very hot after a minute. But the other motor is not. Is the motor defective?
SOURCE: i have an apache 3 channel helicopter.the top
Same problem I had. There are two motors. One to spin the top blade and a second to spin the bottom. My motor was defective out of the box to spin the top blade. Very poor quality as my AH 64 had a bad circuit board. I had to take parts from one to fix the other.
Posted on Sep 12, 2009
SOURCE: Yiboo AH-64 3D RC Mini Apache Helicopter
There is a small set screw on the bottom gear that holds in the upper shaft. You can see these gears through the belly of the helicopter. I had the same problem with the top rotors, and had to go in and re-insert the rotor shaft and tighten the set screw. I applied locktite to the threads to prevent it from backing out. It works now, but one problem I notice is that there must have been a spacer bushing between the two gear wheels. Without the bushing, it will still fly, but I can feel some play in the upper shaft and wonder if over time that the counter spinning gear wheels will start to wear against eachother.
Posted on Feb 10, 2010
SOURCE: crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
dude is your swash plate levle if it is not it will cause your heli to drift
or if not go on youtube and reset your dx6i settings
Posted on Sep 29, 2009
SOURCE: I have Brookstones silver bullet
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Posted on Jan 13, 2011
SOURCE: Just bought a 9053 helicopter.
did you put all 8 of the batteries in it? it takes 8 AA batteries.
Why does my new 3.5CH heli only spin on the ground & lower blades aren't operating. Won't fly. What gives?
Make sure that you charge the batteries overnight. Low battery power will cause loss of power and loss of lift.
Nov 08, 2014 | HobbyTron Phantom 3.5CH RC Helicopter...
Fully charged won't fly. s33 2.4g 3channel with gyro
If you've verified all channel settings and you're sure the battery is charged then it sounds defective. Is it within allowable time from purchase to exchange for a different one?
Jun 01, 2014 | Syma s33 3 channel rc helicopter 2.4ghz...
Hi my son just bought a Micro X Copter Alloy IV 4 channel, it worked at first but after just a few times it no longer will lift. The middle blades and tail blades are not getting enough power. It did not...
Maybe it is out of power an needs a charge? Also, if there is alot of pet hair, dust, and human hair, it could have gotten some in the axels in the blades causing it to spin slower, and could short circut the whole battery if you keep using it with the dust in it. I suggest taking all of the blades and axels and stuff off the main body of the helicopter and take all of the excess dirt and dust off. I hope this helped :)
Aug 22, 2011 | RC Micro X Copter Mini RC Helicopter
I bought rc helicopter of alloy king and i dont know how to make it start.
Insert the batteries into the battery slots in both the controller and the helicopter.now you will be able to control the rc helicopter whenever you want by just switching on the remote control for the device.
May 10, 2011 | Toys
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
My Yiboo Micro Blade Rc copter won't charge. I've tried disconnecting and reconnecting the batteries, but every time I plug it in the charging light doesn't come on and it goes into transmitting mode....
Well my K11 helicopter that I bought from Paddys Markets Sydney Australia last week for $45 gave up after three flights. I suspect the battery is either dead or not charging or a burnt out wire. I suspect your micro RC helicopter has a similar issue. I smashed open my charger with a dumbell weight to see if the wiring inside it was ok. All looks good, but when it is plugged in, it does not even produce heat, which chargers always do to a certain amount. I also dismantled helicopter and took out battery. For $45 it is not worth me buying a voltmeter, another charger (which I cannot find online) and my manufacturer has a dodgy website as well! I recommend keeping your toy for parts and maybe getting another one?
Sep 10, 2010 | Max 2 Tail Rotor Blade For Yiboo Shark Rc...
My rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
May 11, 2010 | RC New 3 Ch Co-Comanche RAH-66 Helicopter
I have an apache 3 channel helicopter.the top blades no longer spin so the helicopter just spins clockwise very quickly
Sep 04, 2009 | Apache RC Mini Helicopter AH-64
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Toys Logo
88 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
