Question about Garden
CSP 3314. The clutch slips and cannot get a good cut. Any ideas?
The engine runs fine and rev's well but as soon as any real preasure comes on the chain it slips and stops turning. How can I fix this?
    Brigadier General:
  • 4,088 Answers
Try washing out the clutch interior with carburetor cleaner from an auto parts supplier and blow out with compressed air.
Posted on Jul 04, 2009
2004 Celica clutch is slipping after car is underway .Say you are going 30 and accelerate the clutch will slip
It sounds like your clutch plate has worn away so slips when under pressure ie,pulling up hill or a heavy right foot.An easy way to test this is to pull your hand break on and try to pull away,if your revs lift without pulling the car then its slipping, there are clutch kits out there for around 50-70,they come with a new clutch plate,new bearing and a new preasure plate.If you do the job yourself make certain that no oily hands or grease gets anywher near the new clutch plate as i found out to my expence.It slipped as the old 1 did so had to do the job twice.Good luck and hope this helps.
Sep 17, 2013 | 2004 Toyota Celica
Tl1000r engine cuts in out in first gear low revs fine in all others also engine stalls when aproching lights etc can anybody shed any light on it
im having the same prob it ticks over fine in neutral but at lights standing still in 1st gear she just wont hold on n dies! So today she's in for full service will report back on spark plug solution! but i think the clutch plates are worn down allowing it to slip out of life!
Aug 04, 2012 | Suzuki Motorcycles
03 KTM 50 Senior Adventure transmission is locked up... The engine runs fine, it just wont turn the sprocket. Any ideas?et
Clutch problem I'm guessing the clutch is slipping and needs adjustment or replacing when clutch went on warrior it would rev and everything just not move when in gear
Dec 31, 2011 | Motorcycles
Received a * used* Swisher ZT 2660 26hp in October of 2010 has 50 hours on the meter. First 2 or 3 cuts all went fine last cut of the year when the mower would contact grass / leaves the blades would...
Is the belt slipping? If it's slipping you'll notice it, because it'll smoke pretty soon. If, as you watch it under varying load, it slows down with the blades then the belt is fine.
If it's not the belt then it's going to be the electric clutch that drives the belt. Get your voltmeter out and tap into the wires that go to the clutch, watch it as the mower runs. Anything under about 13V and the clutch may slip. If the voltage is good then the clutch is worn out. They don't cost too much, I'm pretty sure they're well under $100 still.
Make sure the wires that plug into the clutch are making a good connection. You want to check the voltage between the switch and clutch so that you're also checking the switch- if it's got a little crud in it, or a bad connection farther up the line, it can cause the clutch to slip, and you'll see this as the voltage dropping.
lp
Jan 10, 2011 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Homelite ut-10942-a chain stops under load
Could be the internals of the clutch have been heavily oiled--wash out with carburetor cleaner from an auto parts store. The internals of the clutch expand to the internal rim of the clutch housing when things rev up. Oil blocks the necessary friction needed between those parts. Make sure the chain sprocket is attached firmly to the clutch housing.
Jun 30, 2009 | Garden
Farmal C won't go in gear while running, grinds
I have one that has the same problem,I split tractor to repace rear main clutch an preasure plate,my throw out bearing was bad and the shaft was rusted and would not let the throw bearing go all the way in to the preasure plate
Jun 24, 2009 | Farmall Tractor C ,super Av, Complete...
Ford focus slow at take off
clutch slipping change the clutch
Jun 10, 2009 | 2002 Ford SVT Focus
Gears slip
the transmission is fine its the springs in the preasure plate that have shrunk and the clutch needs to be replaced.
I hope this advice helps.
can u rate the advice please
Feb 26, 2009 | 1996 Ford Mustang
Homelite CSP 3314 Chainsaw
starts no prob will not rev , just stalls when you try
Feb 11, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Poor performance at hi revs on poulan 3314
Try turning the high idle screw out 1/8 to 1/4 turn refer to your manuel for the location of this screw.
Dec 10, 2008 | Poulan Garden
Garden Logo
233 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
