Question about Road Mice 1996 Ford Mustang V6 RM-08FDMGKXA 2011 Mustang GT Wireless C
Lighter wont work
Fuses Are Ok. What can I Check Next?
    Top Expert:
  • 3,698 Answers
The wiring behind the lighter or check the voltage in the socket itself. The center is positive and the side, of the socket, is negative. New replacement sockets are readily available at auto parts stores.
Posted on May 07, 2014
My cig lighter dose't work in my 1992mitusbishi Galant
possible blown fuse or bad ground check wiring to make sure all wires are pluged in if so replace lighter
Feb 08, 2016 | Cars & Trucks
No power to cigarette lighter,2011 lexus es 350. checked fuses ,they are ok.
Use a D C tester and check for voltage it could be a bad lighter. if that dose not work take your voltage tester and put one lead in the lighter hole on the center and ground the other lead to the metal on the car check for voltage. You may have a bad ground.
Sep 28, 2014 | 2011 Lexus ES 350
I have a 1998 toyota corolla ve with electrical problems first it was the dome light the the dome,radio,clock, and cig lighter now its just the clock,radio, and cig lighter I checked all fuses they we
check the fuses again, sometimes they blow right after you install them.
there may be a short in the wiring causing them to pop.
check fuses again and let me know
Dec 11, 2012 | 1998 Toyota Corolla Sedan
12 volt aux plug wont work looked and tested all fuses is there a different location for the fuse for this plug?
most vehicles have a seperate fuse from lighter. on the 2006 it is right next to lighter fuse. hope this helps,
Jul 26, 2010 | 2008 Chevrolet Express
How do i fix my lighter port on my 98 lincoln towncar first and secondery one
First check your fuses using a test light. If all of the fuses are OK, the next step would be to take the test light and touch the center of the lighter socket to see if you have current. If you do touch the side of the lighter with the test light and the clip part of the test light on a hot connection, this way you can see if the ground is working. If the light lights the ground is good. If you had no current check to make sure wire is connected to the lighter. If the wire is coneccted and no current unplug the wire and check just the wire, if you have current then the connection or the lighter itself is bad. If you have no current at the wire you will have to find the break in the wire or run a new wire.
Feb 09, 2010 | 1998 Lincoln Town Car
Power windows & lighter wont work but fuses are good
first what year is the car? now check the fuses with a volt meter . if the fuse is good i would check the back of the cig.lighter center connector for 12 volts and the side of the lighter for a good ground.if all is good the lighter is bad very common. next the windows, i would go to the window relays and check for (2) powers and a good ground.i have seen both motors go bad at the same time. need to remove door panels and check the voltage at the motor.
Nov 20, 2009 | Buick Century Cars & Trucks
Cigarette lighter doesn't work.  Tried replacing fuse, but fuse is ok.  How do you remove the front centre dashbaord panel to gain access to cigarette lighter wiring on a 2005 Jeep cherokee ?
before u pull panel, check for 12vdc with voltmeter inside lighter socket. If u have it, then clean contacts and/or replace lighter(not socket, wiring is fine) May save a lot of work. If you don't have voltage are you 100% sure you have right fuse and not the one below, above, or next to it? I still make mistakes with numbered fuses, which number is for which fuse. To make sure I start counting at 1.
Sep 26, 2009 | Jeep Cherokee Cars & Trucks
Cigarette lighter won't work fuse ok lighter base ok
I would put a red volt meter lead on the middle and a the black lead on the outside. If it checks above 12 vols, the lighter itself is bad. If no voltage is present, you have to check all the positive wires back to the battery. If those are all working, you have a bad ground.
Jun 08, 2009 | 2005 Ford Focus
Road Mice 1996 Ford Mustang V6 RM-08FDMGKXA 2011 Mustang GT Wireless C Logo
62 people viewed this question
Top Road Mice Computers & Internet Experts
sonofspy
Level 1 Expert
Bill Boyd
John Mangan
John Mangan
Are you a Road Mice Computer and Internet Expert? Answer questions, earn points and help others
