Question about Saeco Vienna Espresso Machine
Put 2 spoons of coffee in the by pass dozer
Put 2 spoons of coffee in the bypass dozer and no water came out then they did it right and it worked, 2 days later they did it again then they did it right and it worked now it turns on slowly but then the red light comes on
  • irene May 07, 2014
    this machine has a bypass doser for pre ground coffee
  • vendingbar
    vendingbar May 09, 2014
    Can you tell us the model of your machine? There is a label or under the machine or at the door.
    Problem Solver:
  • 5 Answers
I am not familiar with this machine. Our machine starts with grinding coffee beans, so I have no idea what a by pass doser is or how the machine operates. Sorry! Bob Hempenius
Posted on May 08, 2014
    Problem Solver:
  • 6 Answers
The machine is made to grind WHOLE bean. Why are you trying
to bypass the grinder? The machine measures both bean grinder
and water with timing.
Posted on May 07, 2014
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 48 Answers
What turns on slowly ? Grup - grinter ? What ?
My tray is filling with water and dry grounds are being dumped and no espresso is dispensing.
The passage of water is not passing through coffee grounds. The coffee powder is dumped dry & water is bypassing the brew group and draining into the tray.
Causes:
1- Machine was not descaled. or descaled with automatic method only, as suggested by Jura.
2- There is accumulation of Calcium in the hydraulic system, generating back pressure. This reduces the pump pressure and water cannot force its way through coffee grounds.
3- Stop using filter cartridges. Turn the reminders off.
Solution:
Descale machine manually every three months. See link. Services Unlimited Inc Parts Guru Since 1988
Sep 02, 2016 | Jura Capresso Impressa S9 Coffee...
How do I set up my new 10 cup Bunn velocity brewer to brew only 4 cups?
To do that it is a good idea to put water for four cups and four coffee spoons of coffee. Kolbrun
Oct 04, 2014 | Bunn NHB Coffee Maker
Need to make about 15 cups of coffee, how much coffee and water I need?
Equal amount of water per cup = 15..
About 2 heaping table spoons per cup = 30 tbl spoons.
I also add ground cinnamon right on the coffee grinds
before starting coffee maker
Sep 30, 2012 | Coffee Makers & Espresso Machines
Parts for gran dama 6600
You can order the parts directly from DeLonghi. They stock all the replacement parts. I ordered a milk carafe from them.
Sep 22, 2012 | DeLonghi Esclusivo Gran Dama EASM6600...
Bypass doser doesnt work. I put grinded coffee powder in there and hit the bypass button, then the small coffee button, The machine starts but no coffee dripped but only hot water? Did I do something...
Hi, sounds like your pushing the wrong button or doing the process in the wrong order. If your putting coffee in and only getting water, then that tells me that is is dumping the coffee before it gets brewed. dazza
Oct 08, 2011 | Gaggia Titanium Espresso Machine
Instruction manul missing: I need the water to coffee ratio
2 table spoons of ground coffee per 6 ounces of water.
Mar 05, 2011 | DeLonghi DCU62 Coffee Maker
How do I change the aqua filter in the Saeco Vienna Automatica machine?
it is not a filter but a water softener and no need to replace. You need to pass thought it 2 spoon full of salt desolve with water and then flush it with water for 15 min until the salt will be cleaned. You can do this one time per month so to avoid any scale build inside the machine.
Dec 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Brew head leaks at gasket,causing some water to bypass the coffee and leak around outside of brew head
The filter holder not pushed far enough ino lock position, also the basket doesn't quite hold 2 level spoons of coffee.
Thanks, David
Jun 18, 2009 | Briel Chamonix ES-35 Espresso Machine
Coffee is weak
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Jul 11, 2008 | Bloomfield 8571 Coffee Maker
Saeco Vienna Espresso Machine Logo
104 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
