Why not switching on
Tv not going on when prompted ?
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Sounds like main board fault. Contact any service technician to confirm. Gopakumar Gopalan Google
Posted on May 07, 2014
I have Sony Bravia KDL-46HX800 3D TV. My Ethernet connection stopped working. I can't get IP, my Sony blueray player doesn't have such problem (it is connected to the same net. switch). TV say
use a straight thru to connect directly to the router. Cross overs are typically used when connecting PC's directly together or daisy chaning routers or switches. Try a different port on the switch? Also from a pc, go to the DOS prompt and try and ping your TV. If your TV IP settings are all correct, and your network equipment is working, your should get a response from pinging your TV. If you don't, I would suspect a problem with your TV Enet port.
Jan 05, 2013 | Sony BRAVIA KDL46HX800 46 1080p LED 3D TV...
When tv is off, after some time standby light flashes then switches to orange (as displayed when tv is on). Does this for hours, TV then comes on without prompting. TV is brand new but does this daily.
The problems u describing are causes by the tv power supply board.That the board,where the power a/c cord plug into it.This tv is brand new take ur warrenty repair for the power supply board or take it back where u bought it get a tv replacenent.
Jan 03, 2011 | Grundig GU22DVDPX 22 in. LCD TV
Receiver says INFO NOT AVAILABLE on the Program Guide
Hello, this may have been resolved already, but if you have this issue in the future, here are some steps to help you out!!!! There are a couple different approaches to this. The first, is to go to your guide and press 999 then the right arrow (BROWSE) button, press and release it until the guide prompts a download. If this does not help, or does not prompt the download, go ahead and try this step: Press the MENU button on your remote. Then press the number 6 (System set up), 1 (installation), 1 ( point dish). Then on the upper right of the screen, select CHECK SWITCH. Then, on the bottom of the screen, to the left, you will want to select TEST. Then once it is done testing, you can hit the view live TV button. (If a message comes up after you select TEST, just go ahead and select yes.) I hope this helps!!!!
Becki Barned
DISH Network Customer Service
Dec 19, 2010 | DISH Network Televison & Video
I have a samsung TV that freezes temporarily.
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK
Nov 11, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
My Samsung LNT3253H LCD TV has suddenly started changing its own settings (e.g. picture mode keeps switching to ''dynamic'' and the ''light effect'' keeps setting itself to ''always on''). Any thoughts on...
Its in "Shop Mode".
Change your source to TV (analogue), now press menu>find "Plug and Play" and select it and runs through the setup and selct "Home" prompted and not "Shop".
That should sort its out, when its in shop mode its doesn't matter how many times you make changes, when you power it off it will go back to the original shop settings, this feature was built in to allow shops the have all show TV's to run at optimal settings and if a customer played about with the settings it would matter as they are reset again when the TV is switched off and the store staff don't have to go around resetting all the TV's at the end of the day.
Thanks
Sep 05, 2009 | Televison & Video
Toshiba TV - 29 inch model 2990 XEL
If don't appear display menu when you press this , your tac switch don't work ( menu switch).
May 13, 2008 | Toshiba 27A44 27" TV
Channel stuck on TV
This may work;
info
menu
mute
power
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Feb 24, 2008 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Samsung LE40R73BD DTV freezing, wont chnage channel
info
menu
mute
power
HTH
Oct 24, 2007 | Televison & Video
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
