Question about Tracrac 2008 Toyota Tundra - 5 6" short bed, without Deck Rail System - T-Rac Truck Bed Rack
Truck will not start. Have to wait for 10-30 minutes and then it starts and runs
The truck run good. At certain times the trk will not start. It turns over will not start. Waiting 10-30 minutes trk starts and runs. Looking to see what problem might be
  • Pat Cullivan
    Pat Cullivan May 07, 2014
    this starting issue has been with trk for a couple of years. It will not happen for a while and then it won-t
    Top Expert:
  • 3,698 Answers
Vapor lock. Insolate fuel lines are redirect then away from heat.
Another possible fuel filter is full and needs to be replaced.
Posted on May 07, 2014
Chevy blazer will start then dies, wait 15 minutes it starts and runs good
Trail Blazer has a very cool 'plastic' intake on the Vortex series. I would have the intake checked out, or just replace it with a new one. Don't reccomend a used one since it was a common problem.
Jan 15, 2014 | 2000 Chevrolet Blazer
Driving 2003 f-250 down rd, and all cluster on dash went out then stopped and put trk in park then trk died... Tried starting and everything was dead... Jumped trk off and started up drive for a few miles...
Was the alternator tested off the truck on a bench tester or on the truck with the engine running?
If bench tested check the fusable links at the starter switch and make sure one has not blown. It will stretch like a rubber band if it is blown.
Feb 29, 2012 | 2003 Ford F250
97 lumina, 3.1. Starts runs smooth, drive for 30
I just recently have been fighting the same problem with the same make/model/year vehicle. For myself, I would drive off and on through the day and it would run fine. Then suddenly after a start it would run rough and die. I would have to wait 20 to 60 mins before it would start again. I had it checked and fuel pump was only putting out around 19 psi. It should be around 41 psi. Had fuel pump replaced and no more problems. Furthermore, now it runs so much better. It's funny how over time I didn't notice how the performance was slowly degrading. Unfortunaley fuel pumps for this car run around $300.
May 25, 2010 | 1997 Chevrolet Lumina
No start fuel ok spark ok
throttle position sensor,and crankshaft position sensor.
May 03, 2010 | 2004 Chevrolet Aveo
The 96 park avenue will start great and run great. No security light comes on and everything runs smooth. No bucking or hesitation. A great ride. Then all of a sudden it will die. Lights stay on and radio...
It cannot be the VATS system. The TDM, that is the core of the VATS system, is engaged only at the time you start your car. I have a problem exactly like yours on my 95 LeSabre and just discovered it is the alternator that sometimes charges and sometimes doesn't and when it doesn't, the battery's voltage goes lower than a certain threshold and the computer (PCM) is unable to work anymore and shuts down the engine. Took me months to discover this!
Dec 29, 2009 | 1990 Buick Reatta
Engine runs quiet for about a minute then rattle starts around injector pump area. if i switch of engine and wait for a minute it will start up quite again and then the same again. when the engine is reved...
hi,good day,could be the bracket of your fuel pump is loose,you can try to check it,raise your left rear wheel,(driving direction) remove plastic cover,then you could check visually ,what part is loose,ty
Dec 26, 2009 | 1999 Mercedes-Benz E-Class
Start the bike runs good starts to miss then stall wait a coulpe
Because the problem you describe is intermittent, it is almost certainly fuel related, either the fuel itself or the carbs on your bike.
Before taking it to a dealer or mechanic (or trying to fix it yourself), get a can of Seafoam (I know Autozone has it) and add it to the fuel. It seems to do an excellent job of cleaming out whatever bad stuff accumulates in fuel systems over time, especially carburetors.
There's an interesting review of it at: http://www.webbikeworld.com/sea-foam/
Aug 02, 2009 | 1994 Honda CBR 600 F(2)R
Try to start the truck, must wait ten minutes
imobilizer is faulty. get it checked out.
Jul 18, 2009 | 1999 GMC Sonoma
1996 Oldsmobile Achieva: Security light flashes upon startup
Here is what you do, but only when the SECURITY light flashes - if it is always ON or OFF it's no use.
Turn the key in the ignition to ON.
Wait for exactly 10 minutes ( SECURITY light will flash for 10 minutes and then stay on SOLID)
Turn the key to OFF
Wait 5 seconds.
Wait for exactly 10 minutes.
Turn the key to OFF
Wait 5 seconds.
Turn the ignition OFF.
Start the car normally.
It has relearnt the keycode and you're good to go.
NOTICE - it takes 30 minutes to relearn, that's THREE cycles of ON - 10 minutes - OFF.
Good luck.
Jul 11, 2009 | 1996 Oldsmobile Achieva
Car won't start, wait 15 min. will start but kinda backfires.
possible ignition coil pack breaking down...unit cools off them fires plugs again...fuel pressure is a concern also ..possible failing fuel pump
Jun 25, 2009 | 1995 Chevrolet Caprice Classic
Tracrac 2008 Toyota Tundra - 5 6" short bed, without Deck Rail System - T-Rac Truck Bed Rack Logo
Top Tracrac Boating Experts
Lawrence Oravetz
Timllfixit
Are you a Tracrac Boating Expert? Answer questions, earn points and help others
