Question about Brother Sewing Machine PE500 Embroidery Machine
What do i do if my machine keeps jamming and getting tangled?
I have rethreaded, changed my needle and cleaned the whole machine and its still doing the same thing!
    Top Expert:
  • Brother Master
  • 3,698 Answers
Try adjusting the thread tension.The upper and lower need to match.
In addition the needle needs to be the correct one and installed to the correct depth.
Posted on May 07, 2014
Thread keeps getting tangled in bobbon and wont sew
try changing the needle
rethread using EVERY thread guide
make sure the thread has not come off the thread take up lever
make sure the bobbin is inserted the right way--counter clockwise
make sure the bobbin case is inserted correctly if it's a side or front loading bobbin
clean in the bobbin area and under the needle plate
Dec 15, 2014 | Sewing Machines
It keeps getting tangled up here the bobbin is underneath and keeps getting jammed
try changing the needle--make sure it's the correct one for the fabric
being sewed
rethread the machine ---using every thread guide
try using a different bobbin
try turning the bobbin over the other direction
clean under the needle plate and in the bobbin area for lint
also could be a timing problem and the machine would need to be
checked at a sewing machine repair shop
Apr 12, 2013 | Singer 3116 Simple
How do I fix error E4 whe no thread is tangled?
rethread the machine top and bobbin
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
also possible that something has gone wrong with the computer
part of the sewing machine.
Nov 30, 2012 | Sewing Machines
Bobbin thread tangles
when this happens have you check to see if the thread has come off the thread take up lever?
Feb 09, 2012 | Brother CE5000 Computerized Sewing Machine
Machine Jamming after a few stiches
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
keep a check on the thread take up lever to make sure the thread doesn't come off of it
& bobbin
Check tension 3 or 4 is usually good
Nov 23, 2010 | Brother CE4000 Computerized Sewing Machine
Keeps jamming up
change the needle
clean under the needle plate where the feed dogs are for lint
clean in the bobbin area for lint & loose threads
rethread the machine getting every guide
watch to make sure the thread does not come off the thread take up lever
make sure the bobbin is not warped or damaged
Nov 21, 2010 | New Home HF-106
Thread from the top needle gets pulled and tangled into the lower bobbin.
change the needle
rethread the machine-make sure to get every thread guide
clean under the needle plate where the feed dogs for lint
also clean the bobbin area for lint & loose threads
Nov 20, 2010 | Brother XL-5600 Mechanical Sewing Machine
My machine was working.fine when during a seam it froze. I took off the the bobbing cover and saw the bobbin case had shifted out of place. I replaced it and got the needle moving freely again and now my...
also get a can of air & use it on the bobbin area
change the needle
rethread the machine top thread & bobbin
check the top thread tension
Nov 17, 2010 | Brother CS6000i Computerized Sewing...
My left thread keeps breaking! Its getting snipped by the needle above it. How do I fix this? I've been working on it for 2 hours and read the instructions very carefully, word for word :(
Is this a serger or a sewing machine? :Your needle may have a burr, so change the needle and insert the correct way. Also, check your threading, sometimes your thread gets tangled, rethread.
Aug 31, 2010 | Sewing Machines
Jammed thread.
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Brother Sewing Machine PE500 Embroidery Machine Logo
91 people viewed this question
Top Brother Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
ray gallant
Lawrence Oravetz
Are you a Brother Craft and Hobby Expert? Answer questions, earn points and help others
