Question about HP deskjet 3500 series
How can i install wia scanner driver, i cant scan with my system.
    Top Expert:
  • HP Master
  • 3,698 Answers
Go to the HP website, download the correct driver then install
Posted on May 07, 2014
I have a Canon 4200F scanner and recently purchased a new computer with Windows 7 that is 64 Bit. When I try to use the scanner get a message that I need a WIA driver to use this device. Can you please...
Hi bjgestel !
This means there is no more support from HP for your unit under Windows 7 but Windows has a compatible driver included in it's system ( WIA ) .
The scanner should run smooth but with some restrictive functions . Normaly , it should run without having installed the HP XP driver/ sofware . If this not your case , there is a workaround after you installed the XP driver and made sure installation was successfull . The scanner will need to run with a third party application . Download FreeKapture from
http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Launch Freekapture , clic on Scan , select WIA-Hewlett-Packard . Your scanner will run . If you choose HP's software, program will hang .
Note : no slides or negatives scans possible in WIA mode but the rest works .
Good luck !
fanaudi .
Feb 22, 2011 | Office Equipment & Supplies
Need driver for 4470c scanjet for window 7
Hi zanggerf !
Hp doesn't support your unit anymore since Windows XP . Here are 3 workaround solutions :
solution one:
You can get your unit working in WIA mode if you can follow this :
make sure your XP ( yes XP ) driver is correctly installed .
Launch Freekapture , clic on Scan , select WIA-Hewlett-Packard . Your scanner will run . If you choose HP PrecionScan Pro , program will hang .
solution two :
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
solution three :
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.
Back up your data first.
Have a nice day ,
Best regards,
Fanaudi .
Feb 13, 2011 | HP Scanjet 4470c Flatbed Scanner
Need wia driver for windows 7 32 bit. factory drivers don't work
In any case , make sure the factory driver is correctly installed . If there are no driver available under W7 , install driver XP .
Download and install Freekapture ( http://download.cnet.com/FreeKapture/3000-2094_4-10711598.html )
Load FreeKapture , clic on Scan and select WIA-Canon DR2020U .
Hope it helps ,
Regards
Jan 04, 2011 | Canon DR2020U Flatbed Scanner
Scanjet 4470c. Can't get it to work with Windows 7. Any ideas on a solution or is there a Windows 7 driver out there?
Hi ,
I succeeded to make my Scanjet 4470c run in WIA mode under W7 32-bit Ultimate . Should also work with W7 64-bit .
Make sure driver XP ( yes , XP ) is correctly installed .
Then , download and install FreeKapture ( yes , it's free ) from here : http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Load Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanner works fine in this mode but if you choose HP PrecisionScan Pro , program will freeze .
In any case , no slides or negatives scans possible but the rest works .
Regards .
Dec 13, 2010 | HP Scanjet 4470c Flatbed Scanner
There is no driver for the scanjet 4470c that works with my Vista system on my Toshiba laptop.
Hi ,
Vista or W7 , it's the same problem : there are no more drivers for Scanjet 4470c .
I find a way though , to make the mine work in WIA mode under W7 32-Bit Ultimate . Should work with Vista too .
Make first sure driver XP ( yes , XP ) is correctly installed .
Now , download and install Freekapture ( it's free ) from :http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
In any case , no slides or negatives scans possible but the rest works . As for the buttons , only power button will respond .
Regards .
Oct 09, 2010 | HP Scanjet 4470c Flatbed Scanner
Driver want'
WIA driver for AcerScan 620
*Follow this link from Microsoft to download the latest driver.
*This page provides a list of Windows Image Acquisition (WIA) devices with built-in drivers in the Microsoft Windows XP operating system. There is no need for additional drivers to get the WIA experience out of the box when installing these devices.
*For up-to-date drivers for specific devices, see Microsoft Update.
Jul 11, 2010 | AcerScan 620P Flatbed Scanner
I NEED THE INSTALLATION DISK FOR ACER SCANNER 31OP
WIA driver for AcerScan 320
Jun 14, 2010 | AcerScan 310S Flatbed Scanner
Canon mf4350d WONT scan out of the box
The software that comes with Canon MF4350 does not detect the absence of WIA service running. If printer is working and the correct driver is installed, the first thing to check is: 1. Check that the scanner does NOT appear under Control Panel -> Scanners and Cameras. 2. Navigate to Administrative tools -> Services (the same menu is available under My Computer -> Manage -> Services. 3. Check that service "Windows Image Acquisition (WIA)" is enabled and started. 4. If WIA service is not enabled, enable it. The scanner should appear under scanners menu (see 1.) and Canon MF4350 should work fine.
May 30, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
Communication problem with a MP210 Canon Pixma
Yes! No WIA, no scanning! It means Windows Image Aquisition is not turned on... Not only will the scanner not work but also other Imaging devices like cameras. The best way to find out will be to try and scan from Microsoft Paint. Go to Start, all programs, accessories then look for paint. When paint opens, click file then from scanners or cameras. Try to scan, if it scans then WIA is ok.
It means is the scanner software that was not installed correctly so uninstall reinstall just the scanner software! If Paint does not scan, then its your computer's Operating system (winxp) at fault. Make sure WIA is started, or better try to restart that service (in control panel, administrative tools, services, look for Windows Image Aquisition, restart the service).
Sep 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Download problem
Windows XP supports Astra 610p with its own WIA driver. So to install the WIA driver open the Windows XP controll panel “Scanners and Cameras.
Select the command “Add” and as Manufacturer select “Umax Data Systems”.
Follow onscreen step-by-step instructions to complete the installation for Astra 610P scanner.
May 14, 2008 | Umax Astra 610P Flatbed Scanner
Computers & Internet Logo
67 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
